Brembo rotors not available for EF Civic SI's?????
Old Oct 28, 2003 | 01:41 PM
hugh_jazz_sponer's Avatar
Default Brembo rotors not available for EF Civic SI's?????
I was told that Brembo does not sell rotors for my 91 Civic Si Hatch. Is this true? Thier website doesn't show them either. What are you hatch's upgarding to?
Old Oct 28, 2003 | 02:15 PM
Deetz's Avatar
Crazy Honda Guy
A lot of people in Canada use KVR x-drilled or slotted rotors. They sell for $57 US each and $12 more for cadnium plating. I use them on my cars. PM me if you have any more questions.
Dieter
customauto.ca
Old Oct 28, 2003 | 02:30 PM
USDM 4G VTEC's Avatar
Default Re: Brembo rotors not available for EF Civic SI's????? (hugh_jazz_sponer)
the shop next to my house wich is my buddys sells them for about 30 bucks a piece..... brembo rotors oem replacement
Old Oct 28, 2003 | 05:04 PM
Default Re: Brembo rotors not available for EF Civic SI's????? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the shop next to my house wich is my buddys sells them for about 30 bucks a piece..... brembo rotors oem replacement</TD></TR></TABLE>
so are you saying that Brembo rotors are available for EF hatch's?
what's the difference between EF CRX and EF hatch brakes?
Old Oct 28, 2003 | 05:13 PM
the brakes are the same
xcept i beleive the EX civic model has 1" bigger rotors.....
but all i know of diff are that the 90-91 CRX Si came with rear disc..... other than that the crx and hb shares the same suspension setup...
both of my friends with 89 and 90 HB have brembo rotors....
Old Oct 28, 2003 | 05:14 PM
^jefs0ng's Avatar
Banned
You can get brembos for ef's... there's a dude in sponsors selling brembos right now I'm gonna purchase blanks for my crx.
Old Oct 28, 2003 | 07:22 PM
nautica_t's Avatar
Default Re: (jefs0ng)
i heard teh KVR's are just as good as brembo if not the same, at half the cost of brembo's
Old Oct 28, 2003 | 07:36 PM
EG8R's Avatar
Default Re: (nautica_t)
KVR's are Brembo rotor's that are slotted or drilled....
Old Oct 29, 2003 | 08:34 AM
Deetz's Avatar
Crazy Honda Guy
KVR uses both brembo and euro rotor, i've bringing them in for years. Personally, i can't really tell the diference between the two, except for maybe the box they come in.
Old Oct 29, 2003 | 09:00 AM
nautica_t's Avatar
Default Re: (Deetz)
oh okay, so in other words, KVR's are Brembo's and Brembo's are KVR's. its all of a matter of packaging than. shiet. okay if that's the case, than i rather get KVR's since they are much cheaper down here, and i'll get the cadium coated. thanks for the info. brembo's are so expensive.
Old Oct 29, 2003 | 10:30 AM
Another Drew's Avatar
I don't know how well it applies to your EF, but I recently bought '90-91 CRX brembo rotors and they didn't quite fit my '89 CRX. The rotors scraped on the caliper brackets, but some very thin shims inbetween the hub and caliper bracket solved the rubbing problem.
Old Oct 29, 2003 | 11:03 AM
Deetz's Avatar
Crazy Honda Guy
KVR has different part #'s for 88/89 to 90/91 model cars.
Old Nov 6, 2003 | 08:14 PM
b18crx's Avatar
Default Re: (.jefs0ng)
question. whats the advantage of using brembo brand vs. say any blank rotor?
Old Nov 6, 2003 | 10:29 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: (Another Drew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another Drew &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how well it applies to your EF, but I recently bought '90-91 CRX brembo rotors and they didn't quite fit my '89 CRX. The rotors scraped on the caliper brackets, but some very thin shims inbetween the hub and caliper bracket solved the rubbing problem.</TD></TR></TABLE>
Had the same exact problem. I have a 90 CRX Si with Brembo x-drilled/slotted rotors, rubbed the sides liek crazy, made sooo much noise, all i had to do was like you said, ad a really thin spacer and it solved everything.
Old Nov 7, 2003 | 12:12 PM
bbqman's Avatar
Brembo part number for 88-91 Civic and CRX 90-91dx is 09.5285.10 . The part number for the CRX si all models and 88-89 CRX dx eludes me right now, but I never remember it because there is no need to use it.
Physically the CRX si rotor is the same but 1mm thinner.....don't ask me why...and it has a tendancy to warp easier.
The solution is the thicker one on all models and file the caliper carrier brackets to accept 1mm wider rotors. Simple and I been doing this upgrade for years.
BTW local price for these rotors is 42$ CAN brembo blanks... and if you want both styles are available.
Old Nov 7, 2003 | 12:30 PM
IMO dont buy the cross drilled/slotted Brembos if your looking for a rotor that doesnt warp, because they do. They warped faster than my stock crxrotors Get them if you want that bling factor though, but other than that they dont do ****. I dunno if they work better on other cars or not, but on my crx i warped them about 2 months after i got them. Good luck on finding a place to resurface them too
Japanbomber
Sep 13, 2015 06:54 AM
aasarsak
Suspension & Brakes
46
May 28, 2009 10:05 PM
d16lxciv
15
Apr 16, 2007 07:00 PM
SupraRXZ
10
Oct 25, 2006 01:00 PM
