sohc: vtec versus non-vtec
Old Oct 28, 2003 | 01:09 PM
WangChung's Avatar
Default sohc: vtec versus non-vtec
i have a 97 cx, with the cheese motor d16y7. i have seen some cheap *** swaps around and was wondering how much of a difference i would feel in performance. and also, to anyone who has swapped a vtec engine, just how hard is the wiring? i keep thinkin about this swap, but the wiring part scares me away. thanks.
p.s.-i did a search
Old Oct 28, 2003 | 01:30 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: sohc: vtec versus non-vtec (97civhatch)
if you are going to stick with SOHC then you won't feel a monster gain by swapping in the VTEC SOHC engine. You will def. gain some mid to high range power, but it won't be THAT big of a difference.
If you want MAJOR gains, then swap in a B16 or B18C1 or B18C5 or LS/Vtec or B20/Vtec.. Basically do some research and find out which would suit your needs the most.
As for the wiring. You might want to find out if your car is already wired for vtec.. I'm not sure which EK's are and are not. Either way wiring for Vtec is not that hard to do. Just do some research on that and you'll see what I mean. Once you get over your fear of wiring it will be a lot easier to do.
Old Oct 28, 2003 | 01:40 PM
99blackcivicSi's Avatar
Default Re: sohc: vtec versus non-vtec (Hatchy-Ownzjo0)
How about Mini-me Swap and then boost both cheaply done
Old Oct 28, 2003 | 02:29 PM
Ricey McRicerton's Avatar
Default Re: sohc: vtec versus non-vtec (99blackcivicSi)
Im boosting a y7 and like it. I did'nt care to switch over to VTEC, as there is more room to run a more radical cam without vtec y0!!
Old Oct 28, 2003 | 02:30 PM
Default Re: sohc: vtec versus non-vtec (Ricey McRicerton)
True dat MaNg!
But if he wants V-tEcH PoWa! ( ) he can have both realitivly cheaply
Old Oct 28, 2003 | 02:32 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">How about Mini-me Swap and then boost both cheaply done </TD></TR></TABLE>
Old Oct 28, 2003 | 02:34 PM
Yeah man, gotta have those MaD VtEc SkIlLz y0. The Mini me swap can be found for less than 150 bucks if you know where to look!
Old Oct 28, 2003 | 03:27 PM
JasonBlackEJ1's Avatar
i recommend putting on a vtec head and boostin that thing b/c it will be cheaper. its alot less expensive; and easier to rebuild a head vs. a block which involves engine removal. u could find a vtec head and tranny for like 300 bucks probly. i got my whole y7 swap for 300 and put my vtec head and tranny on it and i love it. (minus my current dilemma)
Old Oct 28, 2003 | 03:43 PM
JMod's Avatar
Default Re: sohc: vtec versus non-vtec (JasonBlackEJ1)
How would just a B18B swap be? Its cheaper than say swappin in a B18C, and your gettin a decent power upgrade over the SOHC motor. And then you can always turbo it, which the B18B is a great platform for. What do you guys think of that? And I mean, i know that the B18B in a LS Teg' can perform just as well stock for stock as a B16 in a Civic Si. So in our Hatch's & Del Sol's it should be about the same or a little better because of the weight. How does this sound?
Old Oct 28, 2003 | 03:44 PM
WangChung's Avatar
Default Re: sohc: vtec versus non-vtec (BucsJosh)
well, i am stickin to sohc's, cuz i am constructing a turbo kit, but will end up doing a mini-me most likely.
Old Oct 28, 2003 | 03:49 PM
civicgsr93's Avatar
From personnal experience,
Best time with a non-vtec engine 16.6 for the 1/4.
Best time with the vtec engine in 15.6 for the 1/4. That was with the same mods, only difference was the engine and tranny.
I would swap the tranny also, gearing is made for vtec with the si tranny.
Jonathan
Old Oct 28, 2003 | 03:50 PM
civicgsr93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civhatch &raquo;</TD></TR><TR><TD CLASS="quote">well, i am stickin to sohc's, cuz i am constructing a turbo kit, but will end up doing a mini-me most likely. </TD></TR></TABLE>
I would do so, try to buy a semi-built vtec head, and an si tranny, your set.
Jonathan
Old Oct 28, 2003 | 03:55 PM
JSPECHB's Avatar
Dont even bother dude. I got the del Sol S with the cheese D15 motor and its a monster. For some reason its not as slow as other D15's I drove. I beat alot of cars off the bottle. LS's and Civic EX's daily.... with the same mods as me.
Old Oct 28, 2003 | 05:28 PM
dohcdelsol's Avatar
Default Re: sohc: vtec versus non-vtec (JSPECHB)
Did you mean ur swapping the same motor that i have in my del??? Its the si but im not exactly sure the code name. Something like D16y7. If i do my gsr swap, ill trade you the motor and tranny for something else. If you want to do that, tell greg and he'll relay the message.
Old Oct 29, 2003 | 04:36 AM
WangChung's Avatar
Default Re: sohc: vtec versus non-vtec (dohcdelsol)
d16y7 is the motor i have (non-vtec). NNNOOOOBBBBBBB!!!!!! hahaha, j/p , but if its the si, it is a d16y8 (vtec, shorter geared tranny) maybe ill pick it up this summer, and lug it back to az in the back of my hatch! seriously . . ..
Old Oct 29, 2003 | 04:46 AM
binkster's Avatar
My friend has a del sol with the d15 and I have a civic ex with the d16y8. he has yet to come even close to beating me, especially at higher speeds, we have the same exact mods.... I dont know what d15 your running....
SOHC_MShue's Avatar
if its from a si then its a 92-95 d16z6 motor.
Old Oct 29, 2003 | 05:00 AM
sohc_boy's Avatar
Default Re: sohc: vtec versus non-vtec (SOHC_MShue)
as mentioned before get an ex/si tranny it will give u the most bang for the buck.
Old Oct 29, 2003 | 05:09 AM
SOHC_MShue's Avatar
Default Re: sohc: vtec versus non-vtec (sohc_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">as mentioned before get an ex/si tranny it will give u the most bang for the buck.</TD></TR></TABLE>
he is right. Your long geared tranny is holding you back.
Old Oct 29, 2003 | 11:51 AM
sohc_boy's Avatar
dependant on what exactly u want to do there are quite a few things u can do to the y7. i have a 99 hatch with the y7 i already swapped the tranny for an si tranny (92-95si not 99-00) that makes a def increase in performance, more so than the typical bolt ons i/h/e. if u just want something a lil more fun to drive just get the tranny and i'd swap the intake manifold for the y8's since u can get them cheap now those mods along with the usual bolt-ons will make for a much more fun car to drive, not the fastest thing but still fun.
Old Oct 29, 2003 | 12:42 PM
WangChung's Avatar
how hard is it to swap trannies? im pretty clue-less when it comes to hands on swapping experience!
Old Oct 29, 2003 | 01:29 PM
WangChung's Avatar
bumpage
Old Oct 30, 2003 | 05:17 AM
sohc_boy's Avatar
its not too bad to do a tranny swap. if u are at all mechanically inclined u should be able to tackle the job. do a search for a how to change an axle that was just posted recently. u have to do that 1st and than u can pull the tranny, i'm pretty sure there were a couple of posts on the tranny subject as well.
Old Oct 30, 2003 | 12:57 PM
WangChung's Avatar
mkoy, thnx
Old Oct 30, 2003 | 01:48 PM
Quad-Damag's Avatar
Im boosting a y7 it is such a champ took 12 psi a few times run it daily driver at 9 psi in a automatic, but doing a 5 speed swap soon
