jdm b16 pistons in LS
they will work as long as they're the same bore, but you may have to have the pinholes widened, and if so, have them re-shotpeened. can anyone else help me out on this one?
they will work as long as they're the same 81mm bore.
_______
I have a set of Stanard CTR Pistons, Rings, and Wrist Pins I will sale for $300 and shipping. Thats if you havent bought any. You can reach me at fast97hatch@sbcglobal.net
_______
yea, they fit on the rods with no modification and -so long as you know what size pistons you need after they bore your cylinder walls- are a direct bolt-on
C/R will be 11.1:1 with the P30's(JDM) and 10.8:1 with the PR3's (USDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djickabod »</TD></TR><TR><TD CLASS="quote">they will work as long as they're the same 81mm bore.
_______
</TD></TR></TABLE> the only thing i will be doing to my block is a lite hone to set my new rings !!!
_______
Yes, as most people said, they will fit with no modification. Just make sure they are the same bore. Stock is 81mm.
Hey, by your zip code, you're located pretty close to me. Maybe I've seen you around. Or maybe you have seen me. I used to drive a red turbo Integra with black Slipstreams. Sold it though.
oink! we put JDM b16 pistons in my friends LS. runs buttah. no modifycations needed. just take them to a machene shop and say "PUT THEM ON BISH!" and they will.
Nautical_Star
Feb 19, 2007 08:43 PM
