clutch too stiff/firm?
Old Oct 28, 2003 | 09:55 AM
civic91's Avatar
Default clutch too stiff/firm?
i''ve been driving an integra 95 and my clutch is not as firm as my 2000 accord lx. is there anything i can do to make my clutch on accord to be less firm/stiff? thanks for any suggestions.
Old Oct 28, 2003 | 11:14 AM
StimpyBoy's Avatar
Default Re: clutch too stiff/firm? (civic91)
I'm just speculating, but I think the firmness of the clutch pedal is a combination of the hydraulics, the clutch pressure plate and the smoothness of the input shaft. The two latter items are hard to change. You can try bleeding the clutch, but I doubt it will make things less firm. If anything it would probably make it even more firm if there was air in the hydraulics.
So unless a 2000 Accord has a cable clutch (which I doubt), I'd say there's not much that could be done. Even if it does, it would probably be more effort than it's worth.
Old Oct 28, 2003 | 11:18 AM
TurboT's Avatar
clutch firmness comes from the spring force of the pressure plate.
The higher the spring force of the pressure plate, the higher the pedal force.
Old Oct 28, 2003 | 12:50 PM
v4lu3s's Avatar
RTFM
i have noticed that accord clutches are not as soft as civic and integra ones.
Old Oct 28, 2003 | 10:38 PM
im_the_teacher's Avatar
Default Re: (v4lu3s)
true, integ and civic clutch are softer than accord.....
true to last post,,,stiffenest and softness depend on the clutch pressure plate teeth and spring.
Old Oct 29, 2003 | 04:06 AM
civic91's Avatar
Default Re: clutch too stiff/firm? (TurboT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboT &raquo;</TD></TR><TR><TD CLASS="quote">clutch firmness comes from the spring force of the pressure plate.
Is it possible to adjust or do something to reduce the the spring force of the pressure plate to make the clutch a little bit softer?
thanks,
bobbilyn
Old Oct 29, 2003 | 06:21 AM
StimpyBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks,
bobbilyn</TD></TR></TABLE>
Other than replacing it, no. And replacing it is basically a clutch job, so it's not for the faint hearted (or those short on time).
You're better off learning to live with it. I drove a 27' U-Haul truck a month ago, now THAT was a firm clutch. I was slamming my Accord's clutch to the floor by accident after driving that truck for a few hours
Old Oct 29, 2003 | 09:56 AM
civic91's Avatar
Default Re: clutch too stiff/firm? (StimpyBoy)
thank you very much guys.....
i_am_greek
Feb 16, 2007 03:22 PM
AFAccord
Jan 25, 2006 12:16 PM
stylett9
Dec 11, 2005 04:13 PM
04accord94civic
May 25, 2005 03:59 AM
joecarguy
May 10, 2004 05:49 PM
