HARD clutch pedal after swap
Old Oct 28, 2003 | 07:48 AM
rextec's Avatar
Default HARD clutch pedal after swap
i swapped this in the b18 into my crx a long time ago and its been running great ever since. when i first finished the swap i noticed the cluch pedal was really hard, and i snapped about 5 pins in the clutch cable. in order to get the stock clutch cable to work i had to jack up my car and then lower it onto some 2x4's so the cluch lever on the tranny would give me enough room to slide the too short stock clutch cable into the lever. has this happened to anyone else? did the 90-91 integra clutch cable fix the hard pedal? if its not this then what may be causing the problem?
Old Oct 28, 2003 | 08:03 AM
bloopie's Avatar
Default Re: HARD clutch pedal after swap (rextec)
Have you tried adjusting the clutch cable?
Old Oct 28, 2003 | 08:21 AM
rextec's Avatar
Default Re: HARD clutch pedal after swap (ZEROsedan)
its all the way loose and i still had to do the 2x4 trick.
Old Oct 28, 2003 | 08:37 AM
EL Vap133's Avatar
Maybe you got a race clutch in the tranny?
Old Oct 28, 2003 | 09:22 AM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
What clutch cable are you using?If you are using the stock crx cable that's the problem.A 90-93 LS clutch cable works perfectly.
Old Oct 28, 2003 | 10:11 AM
turboZChatch's Avatar
you must cut the little rubber end on the cable down about a 1/4of a inch the it will fit just fine if any trouble email back
InJ3cted
May 24, 2005 02:16 PM
lina sok
Sep 24, 2004 03:22 PM
asmallsol
Aug 9, 2004 08:06 AM
coot_er
May 24, 2004 12:12 PM
