Need help with my CRX
Old Sep 5, 2001 | 10:06 AM
REDBARON's Avatar
Default Need help with my CRX
Ok guys here my problem. My tach is not tight. What I mean is that when i rev my car. The tach goes up and down pretty fast but not at an even pace. It just slingshots back and forth. What the hell can I do about that.
Also my other problem is that my speedometer doesn't work. What should I check for first to get it working????
Thanks for your help guys.
By the way, this is on my 88CRX Si.
[Modified by 89-T-Rex, 7:09 PM 9/5/2001]
Old Sep 5, 2001 | 11:07 AM
Brain909's Avatar
Default Re: Need help with my CRX (89-T-Rex)
I dunno If this will help But i had a similar Problem with my 88 CRX. The Tach started to Jump around unevenly and i ignored it. then later on in the same day it stopped all together. i took the cap off distributor and found one of the wire fell off the Ignition module. Might be worth givin it a look. Hope this Help
Old Sep 5, 2001 | 11:13 AM
WuShu's Avatar
New User
Default Re: Need help with my CRX (Brain909)
check all your wiring, sounds like somethings loose.
Old Sep 5, 2001 | 11:14 AM
RyanR's Avatar
For you tach it's probably something to do with you ignitor. Either what the other guy said or it's going bad. As far as the speedo, check to make sure the VSS cable is plugged firmly into the back of the cluster and the VSS.
Old Sep 5, 2001 | 11:29 AM
REDBARON's Avatar
Default Re: Need help with my CRX (97TypeR_9)
So is the ignitor inside the distributor cap?? What's the VSS?
Old Sep 5, 2001 | 11:37 AM
RyanR's Avatar
Ignitor is inside the distributor. The VSS is the vehicle speed sensor.
Old Sep 5, 2001 | 11:49 AM
fixhondas's Avatar
check that your speedo cable is fully inserted into your trans. It could be possible that the cable is broken.
Old Sep 5, 2001 | 11:55 AM
REDBARON's Avatar
Default Re: Need help with my CRX (fixhondas)
Is there anywhere else I should look regarding the speedometer?
And for the Tach, just look in the distributor and make sure all the wires are connected?
Old Sep 5, 2001 | 01:45 PM
REDBARON's Avatar
Hey guys I really appreciate all the responses. I will check the everything today and give you guys a status on it tomorrow.
Thanks again.
Old Sep 5, 2001 | 02:44 PM
fixhondas's Avatar
make sure the wires on your igniter are tight. I usually pull off the connectors and squeeze them with needle nosed pliers.
Old Sep 6, 2001 | 05:01 AM
REDBARON's Avatar
Ok guys, how do I get to my ignitor!! I looked at my dist. yesterday, but what do where is the ignitor. And which wires are we talking about?? ie..color?
Sorry guys, but I'm very new to this.
Canadian_EF
Jul 26, 2010 09:27 PM
frostee trooper
Feb 6, 2005 10:58 PM
Mantis88ls
May 23, 2004 09:13 PM
jdmcx
Jan 20, 2003 08:55 AM
B20zvtecek
May 3, 2002 07:19 AM
