Quick Question on Skunk2 coils
Old Oct 27, 2003 | 09:52 PM
Crxer's Avatar
Default Quick Question on Skunk2 coils
Are the skunk2 coilovers the same for 88-00 civics or is there a specific one for 88-91? I just want to make sure that it will fit without any modifacations thanks in advance.
Old Oct 27, 2003 | 11:49 PM
jc836's Avatar
Default Re: Quick Question on Skunk2 coils (Crxer)
The only difference may be the spring rates and length from one car to another. The Skunk2 sleeves are fairly universal as to the brands of shocks you can use with them (that's why they come with several sizes of O-rings to center the sleeve on the Shock).
I believe you can verify the parts in the online catalog or at worst call Skunkworks.
Old Oct 28, 2003 | 12:01 AM
sporkcrx's Avatar
88-00
Old Oct 28, 2003 | 12:23 AM
Tyson's Avatar
Default Re: Quick Question on Skunk2 coils (sporkcrx)
a great reason NOT to buy skunk2....
also, you should be away koni yellows need a special adaptor or sleeve. GC will provide a specifically made sleeve for these shocks, as well as for different cars for that matter.
Old Oct 29, 2003 | 11:07 AM
Crxer's Avatar
Default Re: Quick Question on Skunk2 coils (Tyson)
Ok i have koni yellows right now and i wanted to get some adjustable coilovers beacuse i wanted to try out 89 accord bilsteins in the front. So if i don't want to run into problems i should get GC's because i will have to buy a special adaptor to put my koni yellow's in the skunks? Will i run into any issues with the bilsteins or the konis in the GC's? Thanks for the info sporkcrx
qnzlude87
Suspension & Brakes
May 3, 2010 11:44 PM
Brand
Suspension & Brakes
23
Apr 5, 2006 12:16 PM
D21X
65
Dec 10, 2004 03:09 PM
singlecamcrx
Dec 6, 2004 08:47 PM
