zex install on d16z6
Old Oct 27, 2003 | 04:34 PM
jl2teg's Avatar
Default zex install on d16z6
what color is the tps wire i need to tap
alsowhat kind of # can i expect w/ 75 shot dry i/h/e.. out of a d16z6
Old Oct 27, 2003 | 06:04 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: zex install on d16z6 (jl2teg)
Its the middle wire, which should be red/blue .... as far as time's that all depends on alot of factors ........"weight of car, driver skill, track conditions,type of tires used etc etc... " .. good luck
Old Oct 28, 2003 | 01:18 AM
Mista Bone's Avatar
D Tranny Guru
start with the 55 shot. You CANNOT run the 75 shot safely without upgrades.
With 75 shot and PROPER fuels mods, 12's are easy.
Old Oct 28, 2003 | 07:56 PM
97hb's Avatar
Default Re: zex install on d16z6 (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">With 75 shot and PROPER fuels mods, 12's are easy.</TD></TR></TABLE>
Old Oct 29, 2003 | 01:40 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: zex install on d16z6 (97hb)
did you wanna say something?
Old Oct 29, 2003 | 02:34 AM
97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">did you wanna say something?</TD></TR></TABLE>
I didn't want to question the great one, but 12's easy. Don't seem that easy if we both aren't in the 12's. Plus you got every trick in the book(good ones that I use all the time) not just a 75 shot and proper fuel mods.
Old Oct 29, 2003 | 10:27 AM
jl2teg's Avatar
what do you mean i cant run a 75 shot
i ran a 75 in my stock teg for a year no prob.. at least 10 bottles
Old Oct 29, 2003 | 10:30 AM
SOHC_MShue's Avatar
he said d16z6
Old Oct 29, 2003 | 11:27 AM
jl2teg's Avatar
Default Re: zex install on d16z6 (SOHC_MShue)
whats wrong with that
Old Oct 29, 2003 | 11:34 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
teg = B18
Old Oct 29, 2003 | 11:39 AM
jl2teg's Avatar
Default Re: (1 point 6)
and ???
I am refering to my sol
Old Oct 29, 2003 | 11:44 AM
mafioso102's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jl2teg &raquo;</TD></TR><TR><TD CLASS="quote">
and ???
I am refering to my sol </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jl2teg &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean i cant run a 75 shot
i ran a 75 in my stock teg for a year no prob.. at least 10 bottles </TD></TR></TABLE>
Old Oct 29, 2003 | 11:46 AM
mafioso102's Avatar
New User
hahaha owned
Old Oct 29, 2003 | 11:53 AM
jl2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">start with the 55 shot. You CANNOT run the 75 shot safely without upgrades.
whatever back to the issue i will run a 75 shot in the sol.. cause i have ran a 75 shot in my teg with no problems back when it was stock.. allthough new to the sohc ness is there somthing i need to know.. or do you guys think it is not safe w/ new ngk's 10 deg. btdc time which is 6 degrees retard, intake, exhaust, and a prayer.
what do you think
Old Oct 29, 2003 | 12:21 PM
dunkd's Avatar
go for it...
a friend of mine ran a 55 on a stock z6 swap'd hatch and ran 14.9 w/ cx tranny if that means anything
Old Oct 29, 2003 | 12:23 PM
Mista Bone's Avatar
D Tranny Guru
With the ZEX and 75 shot you will be on the edge of lean out/melt down. I suggest a .028 fuel jet, 50 psi fuel pressure, and a Walbro 255 HP pump.
Your injectors will still be on the edge, a very FINE edge. Go over 950 bottle psi and you'll be melting plugs.
I melted quite a few myself.......
Old Oct 29, 2003 | 12:43 PM
jl2teg's Avatar
howabout a fmu
Old Oct 29, 2003 | 04:44 PM
mafioso102's Avatar
New User
fmu's are rising rate fuel pressure regulators, measuring an increase in fuel pressure from an increase in boost. Since the nitrous doesn't increase the intake manifold pressure (or wherever you are reading boost from) you wont get a resultant increase in fuel pressure.
Old Oct 29, 2003 | 05:26 PM
jl2teg's Avatar
Default Re: zex install on d16z6 (mafioso102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafioso102 &raquo;</TD></TR><TR><TD CLASS="quote">fmu's are rising rate fuel pressure regulators, measuring an increase in fuel pressure from an increase in boost. Since the nitrous doesn't increase the intake manifold pressure (or wherever you are reading boost from) you wont get a resultant increase in fuel pressure.</TD></TR></TABLE>
the nmu works of vacum just as the fmu and will actually work just fine..
nitrous is boost..
Old Nov 3, 2003 | 06:54 PM
jl2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote"> You CANNOT run the 75 shot safely without upgrades.
well got the kit all together and i am saftly running a 75 shot in my d16z6
i belive it to be running as good as 14.5
Old Nov 3, 2003 | 07:15 PM
SYD's Avatar
SYD
Old Nov 3, 2003 | 07:19 PM
Blackhatch94's Avatar
i ran a 75 shot on my z6 for years with no problem and no fuel upgrades just switched to a 55 cuz im at 140,000 miles
Old Nov 3, 2003 | 08:03 PM
NeVeR bLoWn's Avatar
Default Re: (Blackhatch94)
Before u do anything...you should buy my Zex Cam set up...so you could really feel the effects of that giggle juice
Old Nov 3, 2003 | 08:16 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: (NeVeR bLoWn)
what do you mean by the zex cam "setup" does this include springs, and retainers or just the cam???? and if you have the "setup" could you run a 75 shot with out fuel mods?
Old Nov 4, 2003 | 03:03 AM
japspecjohn's Avatar
Default Re: (preacherboy)
how about in the middle ...65 shot
