89 CRX Si Sunroof Leaking...!!!!!
Old Oct 27, 2003 | 03:34 PM
Gonzo_SiR's Avatar
Default 89 CRX Si Sunroof Leaking...!!!!!
Any of you guys run into the same problem...?
Old Oct 27, 2003 | 03:36 PM
queensny's Avatar
Default Re: 89 CRX Si Sunroof Leaking...!!!!! (Gonzo_SiR)
same yr. same prob.
Old Oct 27, 2003 | 04:20 PM
Quik89Si's Avatar
Default Re: 89 CRX Si Sunroof Leaking...!!!!! (queensny)
Very common problem. Blow out the drain lines, they're probably clogged. Just take off the headliner and you'll see them - there's one at each corner of the sunroof tray.
Alex
Old Oct 27, 2003 | 06:56 PM
Gonzo_SiR's Avatar
Default Re: 89 CRX Si Sunroof Leaking...!!!!! (Quik89Si)
how do I get to the drain lines..? inside of the car...? or outside...?
Old Oct 27, 2003 | 07:23 PM
Quik89Si's Avatar
Inside.
Like I said - pull off the door trims and all the trims that go over the edge of the headliner, then pull out the headliner, and you'll see the underside of the sunroof tray assembly. Then at each corner, you'll see tan-clear hoses that are clipped into the sunroof tray. Unclip those, take some compressed air, and blow them out or clean them out however you possibly can.
Alex
B16CRXVTEC
Oct 14, 2010 08:35 AM
cfwthb_94
Mar 14, 2007 02:16 PM
Vteked
Jan 30, 2004 07:10 AM
OldSchoolCrxSiR
Dec 10, 2002 06:30 PM
dplatt
Jan 8, 2002 04:50 PM
