question for 00 gsr's with VAFC
Old Sep 5, 2001 | 03:10 AM
PROFILES2000's Avatar
Default question for 00 gsr's with VAFC
ok i have had my VAFC in my car for quite some time now, it seems that when i ever i play with my fuel at all i am talking even move it up a point or 2 the darn check engine light comes on and i pull a code 45 which is running to lean or rich.
at this moment i dont really need the extra fuel but there will be a time in the very near future that i will need more what should i do? swap to an obd 1 jumper and ECU?
thanx
Old Sep 5, 2001 | 09:30 AM
Evil DOHC's Avatar
Default Re: question for 00 gsr's with VAFC (ProfileGsR)
If you richen it more than 10 - 15 % you will throw a code. The only way to get rid of it is to switch to an OBDI ecu.
EVIL
Old Sep 5, 2001 | 02:55 PM
blktyper2001's Avatar
New User
Default Re: question for 00 gsr's with VAFC (Evil GS-R)
Import Tuner had the same problem with a 1998 GSR. They ended up taking the VAFC out completely. Try to sell it, and get a fuel pressure regulator.
Old Sep 5, 2001 | 05:05 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: question for 00 gsr's with VAFC (blktyper2001)
I have a '99 and have not had that problem. The only time I threw a too rich/lean code was after I installed CTR cams and found my timing was advanced too far. After I adjusted it to 18 degrees it has been fine ever since. Hope this helps.
Old Sep 5, 2001 | 05:14 PM
FAST94GSR's Avatar
New User
Default Re: question for 00 gsr's with VAFC (Gee3)
switch to obd1. the obd2's car's ecu is very touchy. kenji makes a obd1 .harness get a 94-95 ecu
Old Sep 5, 2001 | 08:41 PM
ninjaman's Avatar
New User
A VAFC is not very reliable for richening. Here's a thread that goes over that issue if you're curious why: https://honda-tech.com/zerothread?id=59518 I use a FPR to richen and a VAFC to lean out the areas necessary.
An ECU for your setup is the ultimate solution because you can also raise the rev limit and edit your timing curves as well. I plan to do this next, but even then I'll use my VAFC to lean out where necessary as each engine is different and I plan to run the Skunk2 program.
ZzZCivicZzZ
Jul 28, 2006 10:52 PM
1999all_motoR_teg
13
Jan 12, 2005 09:53 AM
lePetitePrince
Apr 22, 2003 06:02 AM
billk2k
Mar 7, 2003 12:03 PM
