engine vibrations?
I discovered something wierd today and was wondering if anyone had the same problem. When I am in neutral and i start slowly reving up the engine, I notice when I hit between 2200 and 2500 rpm I get a noticable shimmy or vibration thoughout the car. I also noticed when I am climbing a hill and I put the engine under load, I get shaking though the car too. Most likely the motor shaking. Any ideas? I dont think its a cylender misfire or I would hear it through the exhaust (poping noise).
Check your motor mounts. Mine backed out on the driver side. Its located near the cruise control. Most likely that one is loose. Its a good thing to verify they're all tight while you're at it.
