just did a compression and leakdown test, what do you make of it????
so i'm burning lots of oil and trying to pinpoint the problem, the compression #'s seem good to me, from looking at this does it tell you any obvious problems???
cyl #1 232 leakdown 12%
cyl #2 225 18%
cyl #3 244 10%
cyl #4 232 12%
the bottom end is stock and the motor has 120k on it.
thanks
cyl #2 225 18%
cyl #3 244 10%
cyl #4 232 12%
thanks
When you did the leakdown test where was the air going? How much oil are you burning.
Believe it or not those numbers aren't half bad. The only thing I would be concerned about is #2.
Turn the air pressure down to about 40% and check the whole cylinder through out the stroke. You may have worn or scard cylinder walls.
Yeah, i know it isnt that bad. but i'm burning a quart every 300 miles!!!! we did the leakdown test at 40psi
that is an option, but not at $5 a quart for mobil 1. the oil does come out pretty dirty last time i pulled of the valve cover there wasnt any type of residue.
Fat Chick Magnet
Nov 22, 2006 09:52 PM
model x
Oct 26, 2005 02:01 AM
Sport_Injected
Aug 16, 2004 09:06 PM
