Negative camber... cheep solution ?
Old Sep 4, 2001 | 10:11 PM
X2BOARD's Avatar
Default Negative camber... cheep solution ?
I saw a guy with a G2 teg that did his own rear camber adjustments by changing a bolt somewhere in the suspension.... he used a longer bolt, but I am unaware of how this works.... if that's all you need to do...why do camber kits cost $100+ ?
Anyone know about this ?
Old Sep 5, 2001 | 01:52 AM
Lei Siew Long's Avatar
Default Re: Negative camber... cheep solution ? (X2BOARD)
yeah, most people add washer and a longer bolt in the rear.
Old Sep 6, 2001 | 12:52 AM
Default Re: Negative camber... cheep solution ? (DOHC DX)
quick question...how can you measure if you're at 0 degrees camber or at a decent camber when using the washers and bolt?
TOO MUCH TORQUE
Suspension & Brakes
Aug 14, 2010 08:59 AM
jdmaccord23
Jan 27, 2005 07:58 PM
abeaujuin
Apr 3, 2003 01:43 PM
X2BOARD
Sep 5, 2001 09:14 AM
