90-91 and 92-93 integra ACT clutch kit interchangable ??
hey guys
i just wondering if you guys could help me here
i have jdm honda crx sir , with b16a cable clutch
the only application i can found is the 90-91 and 92-93 cable clutch kit off integra
but i not sure which one of them will fit
oh the gearbox is a Y1 LSD
thanks guys !!!
thanks guys !!!
Y1 is still a small shaft tranny. All B-series cable trannys are small shaft except for the YS1 (from 92-93 Integras... both LS and GSR). But the pressure plates and flywheels are the same... just clutch disc is what you really need to be sure on. When you have a 1st gen B16 tranny (that is not a YS1), then you use a 90-91 Integra clutch kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">Y1 is still a small shaft tranny. All B-series cable trannys are small shaft except for the YS1 (from 92-93 Integras... both LS and GSR). But the pressure plates and flywheels are the same... just clutch disc is what you really need to be sure on. When you have a 1st gen B16 tranny (that is not a YS1), then you use a 90-91 Integra clutch kit.</TD></TR></TABLE>
Cyber ITR
Nov 1, 2003 12:56 PM
