is getting a brake bleeding device worth it?
Old Oct 26, 2003 | 09:02 PM
piotrush's Avatar
Default is getting a brake bleeding device worth it?
I'm going to my first HPDE soon and alot of people suggested changing the brake fluid, so I will. I've never done this before so I want it to be as painless and error free as possible. So, is it worth getting one of those bleeding devices or should I just do the pump and shout method with a friend. If so, what king should I get, will the regular Autozone kind do?
While on brake topic, I will also be gettin axxis ultimates for the front, while doing all this should I invest in some SS brake lines? Thanks in advance guys.
Pete
Old Oct 27, 2003 | 10:08 AM
piotrush's Avatar
Default Re: is getting a brake bleeding device worth it? (piotrush)
no opinions?
Old Oct 27, 2003 | 12:31 PM
irev210's Avatar
makes it alot faster just pumping away with an autozone brake bleeder, but you can do it with a buddy easily, just takes a lil longer.
Just depends how much time you want to spend on it.
Old Oct 27, 2003 | 12:44 PM
speedymon's Avatar
Default Re: is getting a brake bleeding device worth it? (irev210)
Check out speedbleeders.
Old Oct 27, 2003 | 02:09 PM
all stock's Avatar
Default Re: is getting a brake bleeding device worth it? (speedymon)
speedbleeders by yourself.
or just with a friend. both are pretty simple. takes 20-30 minutes if u use handtools on the tires. make sure you use a flare nut wrench. do NOT use any regular wrench to loosen the 10's. they will strip.
Old Oct 27, 2003 | 04:53 PM
Don Napier's Avatar
Import Alliance
Default Re: is getting a brake bleeding device worth it? (all stock)
also get a small tube and a botttle. Put the tube over the nipple on the brake valve and put the end of the tube into the bottle. You will not have brake fluid going all over the place.
TegraGSXR
Jun 9, 2012 10:03 PM
somejaykid
Suspension & Brakes
15
Apr 6, 2012 07:42 PM
kpjo4
Oct 19, 2010 09:48 AM
CPR
Jan 29, 2006 07:48 PM
citanest
18
Jul 6, 2001 01:41 PM
