ITR rear swaybar complete assembly
Old Oct 26, 2003 | 04:26 PM
Ninjaboi_on_X's Avatar
Default ITR rear swaybar complete assembly
This is all the information that I gathered up for what's needed in order to go through with the swaybar:
1.) 52300-ST7-Z01 rear swaybar ($58.30)
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
This correct? And the BSQ kit, I don't know what it really stands for so is it included in the 7 listed? If not where can I get it from and how much does the kit cost. Does Proctor Acura stock it? Thanks
Old Oct 26, 2003 | 04:46 PM
Deluzional's Avatar
Default Re: ITR rear swaybar complete assembly (Ninjaboi_on_X)
Thanks for the writeup though Brett already did this same write up 2 years ago and its still on his site for the itr sway
Old Oct 26, 2003 | 04:52 PM
No I was asking a question. Is the BSQ included in there? or do I have to order that separately from somewhere else?
Alexander's Avatar
Default Re: ITR rear swaybar complete assembly (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the writeup though Brett already did this same write up 2 years ago and its still on his site for the itr sway</TD></TR></TABLE>
Uhh... I'm pretty sure he wasn't providing a writeup of the parts.. but instead asking if it was the correct list
The BSQ kit is not a dealer part, but rather a Do-It-Yourself kit made by BretQ, or BSQ here on Honda-Tech.. His website seems to be down but do a search for "BSQ" and you will find all of the info you need.
Old Oct 26, 2003 | 04:56 PM
Default Re: ITR rear swaybar complete assembly (Alexander)
thanks alot Alexander
Old Oct 27, 2003 | 01:07 AM
slomob18b's Avatar
You can get the BSQ kit from here: http://www.geocities.com/bretq/mounting_kit.html
or
You can go with the Beaks kit:
http://www.beaksproducts.com/products.html
Dsee2
Dec 9, 2003 08:47 AM
roninb18
Jan 30, 2003 06:09 PM
speedymon
Dec 10, 2001 08:48 AM
SilverGS
Nov 14, 2001 10:25 AM
gsr94
Aug 15, 2001 03:30 AM
