CEL comes on at autox?????
Old Oct 26, 2003 | 03:41 PM
jeddy0120's Avatar
Default CEL comes on at autox?????
today i went to my 2nd autocross event and it was raining most of the day, i was proceeding on my 2nd run when i lost control due to my lack of experience and the rain, and spun out. the car rotated so i was facing the opposite direction and i stalled. As i tried to start the car again it took a while for it to turn over. Immediately after that the check engine light came on and i could not rev over 3,000 rpms
just wondering if anyone has had this happen to them and if it could have caused some damage.
I was talking to some of the guys a the event and they said it could have been from a drop in the oil pressure as the car spun. one of my friends also has an ep3 and he spun out as well but he was fine.....
Old Oct 26, 2003 | 03:49 PM
anjapower's Avatar
Default Re: CEL comes on at autox????? (jeddy0120)
should add that oil level was fine and the gas cap was screwed on tight....after removing the battery cable for a few minutes and hooking it up again, the CEL went away.
Old Oct 26, 2003 | 04:59 PM
darkvibe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeddy0120 &raquo;</TD></TR><TR><TD CLASS="quote">it could have been from a drop in the oil pressure as the car spun</TD></TR></TABLE>
That sounds right to me. Seems like the most common cause of limp mode is low oil pressure.
Old Oct 27, 2003 | 10:04 PM
dacaveman's Avatar
Isnt that known as safe mode? For when the car believes there is something wrong. Most likely oil pressure.
Old Oct 28, 2003 | 10:47 AM
B18CXr's Avatar
sorry but incorrect on the oil pressure.... the oil pressure switch is a binary switch and does not connect to the ECU, only the MUX and dash light.
most likely the CEL was either a CKF or misfire code
Old Oct 28, 2003 | 10:49 AM
B18CXr's Avatar
Default Re: CEL comes on at autox????? (darkvibe)
this is partly true but only due to the VTM, NOT the oil pressure switch, signal fluctuating
Old Oct 28, 2003 | 12:21 PM
anjapower's Avatar
Default Re: (B18CXr)
what's a CFK?
Old Oct 28, 2003 | 03:07 PM
Essence of Chicken's Avatar
Please tell me you depressed the clutch when u spun.
Old Oct 29, 2003 | 07:36 AM
B18CXr's Avatar
Default Re: (anjapower)
what's a CFK
opps, my bad, CKF (i always mix that one up)
Crankshaft Speed Fluctuation Sensor
97civicgirl
23
Feb 18, 2011 10:32 AM
souljaboy
Honda Civic (2001 - 2005)
11
Nov 14, 2007 05:45 PM
98GSRrdr
Feb 20, 2007 12:52 PM
SoftieB16
Jun 15, 2004 12:52 AM
shoebox
May 13, 2004 06:57 PM
