pm6 7, 10,20
Old Oct 26, 2003 | 02:10 PM
Escabar's Avatar
Default wont fire
read down
Modified by Escabar at 1:23 AM 10/27/2003
Old Oct 26, 2003 | 02:15 PM
AbaZ's Avatar
Default Re: pm6 7, 10,20 (Escabar)
http://www.hondata.com/techecucodes.html
wouldnt worry about 10..
Wont start as in.. wont crank? No fuel? No spark?
Old Oct 26, 2003 | 02:18 PM
Escabar's Avatar
Default Re: pm6 7, 10,20 (AbaZ)
it jsut clicks when i fully turn the key. starter isent turning over.
Old Oct 26, 2003 | 02:29 PM
AbaZ's Avatar
Get a jumper on there from another car with a known good battery. Or take your battery out and put a new one in. If it continues to just "click" ensure the starter signal wire is plugged in on the tranny, and you may just have a starter going out. a Real easy way to tell is, have someone turn the key over while another person takes a long punch, or anything hard and just tap on the end of the starter solinoid, then it should turn over.
Old Oct 26, 2003 | 02:53 PM
USDMMARK's Avatar
deff. check that battery
Old Oct 26, 2003 | 04:14 PM
Escabar's Avatar
found out why starter dident turn over, not use to new cars where u gotta push in the clutch befor car will start, doh! anyways i got the car to turn over but it wont fire, its getting gas spark and sucking in air so i messed with it some more and found the 2 sensors on the back of the intake manifold arent plugged in, and one of the vaccum hoses isent hooked up... im gonna try to get these problems worked out and try to get this bitch to FIRE!
gooblinn258
Dec 16, 2013 08:23 AM
DriveSlowHomie
Jan 26, 2010 10:31 PM
go2sleep
May 6, 2007 08:42 PM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
vtecdc2
Dec 1, 2002 11:35 PM
