milling the head...
Old Oct 26, 2003 | 10:35 AM
Ronin Panda's Avatar
Default milling the head...
how much can i safely mill my head?
its a b16a
also i wanted to do a 3 angle valve job to put some skunk 2 high comp valves in..does anyone have a rough idea of the price for both of these services?
Old Oct 26, 2003 | 11:01 AM
crxste's Avatar
Default Re: milling the head... (Touge Panda)
What Block?
What Pistons?
What Cams??
Old Oct 26, 2003 | 11:33 AM
Default Re: milling the head... (crxste)
stock b16a block
JUN II cams and skunk 2 valve train with a spoon hedgasket
Old Oct 26, 2003 | 01:08 PM
DVS_EF's Avatar
.030".....try that, you should be safe, then clay your motor
Old Oct 26, 2003 | 01:13 PM
ENDYN's Avatar
The Old One
Default Re: milling the head... (dvsEF)
If you have stock pistons, don't whack more than .012" MAX, or you'll have piston to valve problems...
Old Oct 26, 2003 | 01:14 PM
Fkned's Avatar
the head has an indicator pad on deck,it's safe to mill to that point only.
Old Oct 26, 2003 | 01:41 PM
91integraLSVTEC's Avatar
Default Re: milling the head... (fkned)
my b16 head has been milled to.030 with skunk stage 2 cams.. both cam gears has been advanced.. no problems
monster_c
Nov 26, 2011 12:23 AM
EGtypeR408
Oct 15, 2010 04:57 PM
k20o2o4civic
Mar 6, 2009 08:21 PM
VTECROAR96typeR
Dec 28, 2008 06:01 AM
