car stalls when brakes applied HELP
Old Oct 26, 2003 | 10:06 AM
joeski's Avatar
Default car stalls when brakes applied HELP
ok so for some reson when i apply the brakes the vac pressure goes for -20 to -10 the motor dies down a lil then when the brakes are fully pressed the car stalls
can anyone help me out im so lost
93 si
thanx
Old Oct 26, 2003 | 10:22 AM
NonovUrbizniz's Avatar
Loved
Default Re: car stalls when brakes applied HELP (joeski)
sounds like a vacum leak... I'd check the vacum lines going to the booster and to the fpr...
Old Oct 26, 2003 | 10:58 AM
joeski's Avatar
Default Re: car stalls when brakes applied HELP (NonovUrbizniz)
yea theres something goin on between the intake manifold and the brake master cylinder btw i havea gsr motor
do u think getting a gsr master and booster cylinder will mby fix this problem
Old Oct 26, 2003 | 01:22 PM
Loved
I don't know...
I'd test things and see if they're in spec...
Like I said... I'd check the vacum LINES going to the FPR...
I wouldn't go replacing a whole master/booster unless they're bad... which it doesn't sound like they are.
Old Oct 27, 2003 | 02:33 PM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a vacum leak... I'd check the vacum lines going to the booster and to the fpr...</TD></TR></TABLE>
Old Oct 27, 2003 | 02:40 PM
b20turbojason's Avatar
check the vac line from the booster to the manifold there might be a crack in the line.
lsnidex
Suspension & Brakes
Jun 3, 2009 08:27 PM
moco_machine
Aug 17, 2008 02:13 PM
G0crxG0
Feb 27, 2008 09:33 AM
n00bfasho
Dec 28, 2006 06:38 PM
crxtreme27
14
May 16, 2003 12:19 AM
