Stock bastard radio won't come out + pics of DIY paint job
Damnit, I've been trying to get it out for like an hour. BTW, it's a '94 CX. I got the bottom panel off and looked under but there's no screws that looks like they're holding it. There's some on the back which you can see in the second picture but it doesn't look like they're holding the radio. I can't get to them anyways. I've looked through a bunch of threads on this topic but I still can't get it out. Can you guys help me out. What holds the radio in?
Threw in some pics of my paint job on rear quarter.
Crews look like their just holding the plastic dash to the metal frame.
Car looks blue in this pic:
There should be 2 8mm bolts behind the deck that are holding it in. If thats not it remove the front panel of the deck. Pull of the ***** and the the trim panel and see if there are tabs holding it in
thats a double **** deck...you u need to pull off the ***** on both sides, and there should be a nut behind. unscrew, and remove the plate, there might be some brackets that u need to maneuver
Finally! I got it out. Thanks guys.
I went through all the archived posts and nobody ever mentioned the clips in the front.
