neon above pedals
My friend gave me a little neon and I want to put it where the light shows on the pedals... well (im noob) I look up under there (above the pedals) and theres a million and one wires.. I have no idea which one to hook up too and my friends bro said that I would need a switch(where can i get one ? )
thnx
thnx
You can get a switch from any electronics store. The wires that are under there should not be messed with. You basically need 3 wires: Positive, Negative, and ground. The easiest/messiest way to do it would be to run wires from the switch to battery and find a ground somewhere. Someone else could probably give a better suggestion though.
Nick
Nick
the stock radio (for 4th gen at least) had a wire for lights, almost all aftermarket radios light up all the time and do not need this light wire so if you have an aftermarket radio, u can just use that wire so when u turn on the lights the neon will light up since ur only gonna use it at nite, thats how i did my gauges, if u dont have an aftermarket radio, u still could just tap into that wire, but i dunno if that would be suckin too much juice and melt the wire, i dunno enough bout wire size and all that....
I believe you're talking about the dimmer wire. that'd work.....the other option is to get a switch at rat shack, and install that in a location of your choosing, and run a wire from the battery or whatever other power source is closest and that you can tap safely.
- Nathan
- Nathan
if you tap into the dimmer switch the neon thing will turn on with your headlights, you can also hook up a switch inbetween the dimmer wire and the neon so you can still turn it off at night if you arent in the disco inferno mood.
bradtricker
Audio / Security / Video
Nov 4, 2008 07:09 PM
broketuner-Sol_Si
24
Oct 7, 2006 03:54 PM
ProjectCRXtacy
23
Oct 18, 2004 02:21 PM
jemdogs
Oct 4, 2004 11:44 PM
rafimos
Nov 5, 2002 09:01 PM
