******D16Z6 Rebuild******
Old Oct 26, 2003 | 01:03 AM
0ptimus prime's Avatar
Default ******D16Z6 Rebuild******
Well, i just picked up two d16z6 long blocks. One block is bad because the part that connects to the motor mount is broken off of the actual block - this is too dangerous to weld. The other was knocking when it was pulled out and replaced.
My goal is to pull out the internals from the useless d16z6 block, and rebuild the knocking long block. In the process, i'm also going to do a complete rebuild.
What do you all think i should replace when rebuilding it? Gaskets, seals, belts, etc. Thanx in advance.
Old Oct 26, 2003 | 01:18 AM
Tad's Avatar
Tad
imo, if your going to replace internals,
shouldnt you replace them with parts that will increase performance? instead of used stock parts?
do something to beef that baby up!
Old Oct 26, 2003 | 01:34 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">imo, if your going to replace internals,
do something to beef that baby up!</TD></TR></TABLE>
yeah. Do it now...you'll love yourself.
Think about doing an OEM build using maybe D16A6 pistons perhaps.
You can also pick up a full gasket set for under 100 bucks also.
This along with a crank grind, freshen up the cylinders, maybe a rebuilt head with a p&p and a cam, could see some good results
Old Oct 26, 2003 | 07:42 AM
blackeg's Avatar
Default Re: (Emerika)
definately do a rebuild with preformance parts while its all apart. its just easier. try some srp 10.5 comp pistons, some forged rods or maybe machined ls rods, new gasket sets, zex cam, cam gear, i/h/e and some other bolt ons and u should be pretty happy. oh- look into the hondata intake heat shield/gasket thingy. it made a noticable difference in temp between my im and my head
Old Oct 26, 2003 | 10:34 AM
BatuKing's Avatar
Default Re: ******D16Z6 Rebuild****** (Captain Hammerite)
When you swap parts please dont swap the cranks caps.. they are not interchangable. Also you might as well get new pistons rings and bearings.
Old Oct 26, 2003 | 11:20 AM
4door93civic's Avatar
Default Re: ******D16Z6 Rebuild****** (BatuKing)
need a d16z6 head? 130 plus shipping
Old Oct 26, 2003 | 11:21 AM
Default Re: ******D16Z6 Rebuild****** (4door93civic)
whoops i didnt see the part where it says longblock that means you have a head sorry
Old Oct 26, 2003 | 08:59 PM
i don't need new pistons, i'm using the rods and pistons from the 40k longblock; the only prob with it is that it won't hold in the engine bay, hence i'm rebuilding the other knocking long block w/ the good parts from the other.
Old Oct 26, 2003 | 11:04 PM
bump
Old Oct 26, 2003 | 11:27 PM
AlphaQup's Avatar
I'm currently in the same situation as you are. I need a set of A6 pistons to complete my parts list. If anybody reading this thread has a set, please let me know. (sorry don't mean to hi-jack this thread) I'll keep posted as well on my build.
Old Oct 27, 2003 | 01:23 PM
it's kool alpha, what parts are you rebuilding on your d16? (parts list)
Old Oct 28, 2003 | 03:29 PM
AlphaQup's Avatar
Default Re: (Captain Hammerite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Hammerite &raquo;</TD></TR><TR><TD CLASS="quote">it's kool alpha, what parts are you rebuilding on your d16? (parts list)</TD></TR></TABLE>
all stock internals
-ls rods or shot-peen z6 rods
-arp head bolts
-y8 head gasket
-new waterpump
-new oem piston rings
-new oem rod & crank bearings
Old Nov 2, 2003 | 01:08 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Hammerite &raquo;</TD></TR><TR><TD CLASS="quote">i don't need new pistons, i'm using the rods and pistons from the 40k longblock; the only prob with it is that it won't hold in the engine bay, hence i'm rebuilding the other knocking long block w/ the good parts from the other.</TD></TR></TABLE>
you dont get out point,
were saying ditch those stock parts you have, sell em off or something.
its not worth the EFFORT to stick them in an engine, when you could put in some GOOD parts.
Old Nov 3, 2003 | 10:03 AM
thisbugger's Avatar
just put some time-serts in the block that has the broken motor mount. it'll be like new
Old Nov 8, 2003 | 08:26 PM
Snail Tuning's Avatar
Default Re: ******D16Z6 Rebuild****** (tjsEG6)
i just picked up a z6 and a y8 longblocks for cheap. desided to go with the z6.
hears my list
eagle rods, JE pistons comp 9:5:1
new bearings, washers and thrusts.
New gaskest and head gasket. honda OEM
new stainless valves, crower springs, and possably a zex turbo cam.
block gaurd and possable some port and polish head work and a 3 angle valve job.
ill then run 12-20 psi on this setup. if your ganna take the time to do the work either use high come oem pistons, or use aftermarket forged pistons and turbo it.
Old Nov 8, 2003 | 10:30 PM
blackeg's Avatar
Default Re: ******D16Z6 Rebuild****** (bmcc72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmcc72 &raquo;</TD></TR><TR><TD CLASS="quote">i just picked up a z6 and a y8 longblocks for cheap. desided to go with the z6.
hears my list
ill then run 12-20 psi on this setup. if your ganna take the time to do the work either use high come oem pistons, or use aftermarket forged pistons and turbo it. </TD></TR></TABLE>
i didnt know that zex made a turbo profile cam for the sohc vtec? anyway, dont forget fuel system upgrading for boost!!! tuning is critical too. and i think u might have to notch the block to fit the eagle rods in. ive heard this before...look into it and good luck with your build- i shoulda turbo'd my z6, but i went with nitrous instead.
Old Jul 9, 2004 | 05:26 PM
rice a roni's Avatar
Default Re: ******D16Z6 Rebuild****** (blackeg)
when you rebuild with aftermarket pistons do you have to bore the cylinder so it gets wider? or are the pistons the same size as stock?
5speed4life
Sep 1, 2009 07:59 PM
4ghatch
Apr 24, 2008 09:00 AM
mugenkilla899
Nov 10, 2006 01:06 PM
fms1day
Northern California (Sales)
Sep 1, 2006 11:03 AM
