Tips/tricks on polishing daisy style GSR rims?
Old Oct 25, 2003 | 11:53 PM
EK22Tim's Avatar
Default Tips/tricks on polishing daisy style GSR rims?
Hey guys,
I have a set of the daisy style GSR rims that are in OK shape- They have some corrosion, etc. from salt and snow. What I was thinking of doing was polishing them- essentially sanding the clearcoat off them, wetsanding the machining marks (Rings) and corroded spots off them, then polishing them with a polishing wheel, and finally clearcoating them with 3-4 coats of clear to protect them.
I did a search on more info and came up empty, so if anyone has ever done this, or knows any tips/tricks/things to look out for or reasons I Should not do this, please post them here. Pics would be cool too, thanks!
I think I remember seeing this done on some GSR blades once, but that was like a year ago, and I don't think it had 'polish' in the title. Anyway, let's see what you have?
Old Oct 26, 2003 | 07:53 PM
EK22Tim's Avatar
Default Re: Tips/tricks on polishing daisy style GSR rims? (EK22Tim)
Anyone??
Old Oct 26, 2003 | 10:03 PM
drevinder's Avatar
i got blades so iam interested in this to
anyone post up if they got info
Old Oct 27, 2003 | 05:51 AM
jweller's Avatar
Default Re: Tips/tricks on polishing daisy style GSR rims? (drevinder)
eastwood sells a wheel polishing kit that has all the buffers and compounds you might need to do it. kind of pricey, but it's complete, and they have nice stuff.
http://www.eastwoodco.com
Old Oct 27, 2003 | 05:54 AM
-DC2-'s Avatar
use aircraft stripper (blue can) LIBERALLY to remove all the OEM clear coat
under that is a nice polished alloy surface. if necessary wet sand with 800-1200 grit paper to remove corossion. then use a polishing compound to buff out the wet sanding.
Old Oct 27, 2003 | 07:44 AM
ebelp's Avatar
Default Re: (DOHCDX)
Daisy style? That's a first. Anyway, I wouldn't strip off the oem clearcoat unless it's already starting to peel off. I'd go with Mother's polishing compound...
Old Oct 27, 2003 | 08:53 PM
EK22Tim's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Daisy style? That's a first. Anyway, I wouldn't strip off the oem clearcoat unless it's already starting to peel off. I'd go with Mother's polishing compound...</TD></TR></TABLE>
LOL yeah, that's all I've heard them called? Or 5 spoke style. Anyway, yeah, they're pretty corroded around the rim, already did polish them with Mother's but I was thinking strip the clearcoat, wetsand them and polish them to a mirror shine instead of the machined look, and re-clearcoat.
2ndName
Jan 8, 2006 07:29 PM
Vtec-IsMyAntiDrug
Sep 8, 2004 08:05 PM
ShiftSpeed
Jul 9, 2004 06:23 PM
Adam.
Apr 9, 2004 04:45 PM
thaigsrdrv16
May 31, 2003 07:31 PM
