Keyless entry-do i need relays?
I have a viper 600 esp alarm, I installed all of the alarm with no problem. Now, my actuators are mounted and I need to know how to wire them up. The instructions that I have are not very helpful. They are DEI actuators, and my car is a 1996 civic cx. Does anybody know whitch wires go where?
if you didn't have factory power locks, then yes, you'll need to use relays.
The easiest way is to use the DEI 451M. Pretty straight forward and has both relays packed and wired neatly in one little box. You wire this up to your actuator, and plug the small 3 wire plug from it into your alarm's brain, and you're done!
the 451m will have a harness w/ a red, green, and blue, wire your red to 12volt constant, blue and green to the blue and green coming off the alarm.. or if your 600esp is a newer one and your 451m has the built in plug then plug it into the brain. then you will ground out your white and brown w/ black wires, and give the purple 12volts, and then connect the blue and green w/ black thick guage wires to the actuators and your all done
watacivic
Audio / Security / Video
17
Apr 17, 2007 12:53 PM
92civeg
Dec 13, 2003 11:42 AM
