bad fuel pump?
This problem just started just a few days ago. The car started skipping, and i mean shutting down skipping but the power wasn't cutting out. At first I thought ground/battery strap but no all my big grouds are secure and the power isn't shutting off. Then I noticed that when going around corners I was getting a little electrial popping noise down in my underdash fuse box region. So I let the car idle and wiggled all my conections and fuses, nothing. Then I ran the car down the block and pulled a hard right hander and the car died. I tried starting it but no good it would just crank. Then I noticed that I could hear the pump fluttering away. I figure the sound was eminating up through the fuel lines but is there a relay in the drivers footwell that might be bad or could it be the pump. I let the car site for 1/2 hour and then it fired and I drove home. Stumped help is appreciated. BTW thsi is a 95 cx with a d16z6 swapped in. Did I kill my pump with the hotter engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 »</TD></TR><TR><TD CLASS="quote">do I need to remove the dash to get to it? IS this a common problem?</TD></TR></TABLE>
For an older Honda I would not consider it such a rare problem. My 90 hb has an issue similar to yours occasionally, but I have yet to determine the exact problem.
The interior fuse panel is under the steering wheel to the left a little bit.
