dc2 suspension components compatible with EF?
Is anyone using shocks and springs from 94+ integra on their EF?
I'm wanting to use some itr shocks and springs, although I know it will sit high - but maybe I can use and aftermarket coilover kit?
What will/ won't fit, and why?
I've heard that some parts (like koni yellows) are the same part # for itr and crx.....
Anyone?
Anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">I've heard that some parts (like koni yellows) are the same part # for itr and crx.....
thats the 88 rex rear only shocks , they have the nice ITR style LCA's
if you use the front shock forks any DC/EG shock will fit , but I think the shocks on the EF are much shorter...
wait for someone else to chime in for sure...
Rear fits fine as long as you have the proper LCA for your shock bottom.
Front fits fine as long as you use the DC2/EG front forks.
This will make the front of the car sit higher, but with a coliover system you can compensate.
Thanks guys! Wow, that took you all of 5 minutes!
I have itr lca's and itr front forks, so I should be good to go!
Now what springs should I use with stock itr shocks on an ef.....? hmm.....
lonefuzzy79
Nov 19, 2005 02:06 AM
Black R
13
Aug 12, 2005 09:13 AM
Pharnos
Nov 1, 2002 06:58 PM
