Can you use OBD2 o2 sensor in a OBD1 car?
Old Oct 25, 2003 | 09:37 AM
Del_Slowest's Avatar
Default Can you use OBD2 o2 sensor in a OBD1 car?
Can you use OBD2 o2 sensor in a OBD1 car? They are both 4 wires so i wouldn't see why not.
Also, autozone sells 1 wire o2 sensors for 18 bucks. can i buy one of those and just hook up the white wire and the grounds and not use the green wire ( heater one ) ?
Old Oct 25, 2003 | 10:43 AM
Shawn C's Avatar
In The Garage
the black wires are heater wires. the white is signal, and the green is ground. you can use an obd II sensor. you can't use a 1 wire. they aren't very accurate anyways.
Old Oct 25, 2003 | 11:07 AM
Ricey McRicerton's Avatar
Default Re: Can you use OBD2 o2 sensor in a OBD1 car? (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest &raquo;</TD></TR><TR><TD CLASS="quote">Can you use OBD2 o2 sensor in a OBD1 car? They are both 4 wires so i wouldn't see why not.
Also, autozone sells 1 wire o2 sensors for 18 bucks. can i buy one of those and just hook up the white wire and the grounds and not use the green wire ( heater one ) ?</TD></TR></TABLE>
Don't waste your 18 bucks. It's not going to work right. Just get a 02 from here in the classifieds or from a junkyard or something if you don't want to pay the dealership the 200 bucks for one.
Old Oct 25, 2003 | 11:35 AM
Shawn C's Avatar
In The Garage
also, 96-00 HXes have a wideband 4-wire O2 thats supposed to be a nice upgrade. it's really accurate and is good for turbo cars.
Old Oct 25, 2003 | 01:25 PM
Default Re: (ShadyED9)
thanks. I picked up a D16y8 one from a fellow H-T member ( inspyral ) Can't wait to hook it up
94GSRMR
Jul 7, 2010 03:30 AM
3rdgencrx
Mar 8, 2007 04:34 PM
jayare05
May 17, 2006 02:17 PM
Mach69
Dec 21, 2004 08:16 PM
