B16 EF No Start!!!
Old Oct 25, 2003 | 09:13 AM
RobbieG35's Avatar
12 Years Strong
Default B16 EF No Start!!!
I have spark and plenty of fuel but have no start. I wired the round Si dizzy plug to my DX harness and its sparking but no start. Any suggestions?
Old Oct 25, 2003 | 09:19 AM
youngwon22's Avatar
obd-1?
Old Oct 25, 2003 | 11:17 AM
civickiller's Avatar
Default Re: (youngwon22)
check your timing, just because its firing doesnt mean its firing at the right time, and check your compression just to make sure
Old Oct 25, 2003 | 11:34 AM
spaceman's Avatar
Default Re: B16 EF No Start!!! (HybridHatch88)
need more info on your setup,is it cranking over?..check your grounds
Old Oct 25, 2003 | 04:36 PM
kranked91dx's Avatar
Default Re: B16 EF No Start!!! (spaceman)
eratic clickin of the main relay ( if occuring, ) or no cliking at all of the main relay (not supposed to happen, if you got fuel, you main relay is clicking ) are often in relation with the grnd on the the thermostat housing.
Old Oct 26, 2003 | 07:52 AM
RobbieG35's Avatar
12 Years Strong
Its 0BD0. It is cranking over. It fired when I took out one of the plug wires and grounded it but then when I tried to start it again later it didnt fire??? The dizzy that came with the motor was bad so I got one from H motors. Main relay is not clicking. Im going to check the timing, compression, and my grounds just to make sure. Any other suggestions?
Old Oct 26, 2003 | 04:59 PM
youngwon22's Avatar
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Its 0BD0. It is cranking over. It fired when I took out one of the plug wires and grounded it but then when I tried to start it again later it didnt fire??? The dizzy that came with the motor was bad so I got one from H motors. Main relay is not clicking. Im going to check the timing, compression, and my grounds just to make sure. Any other suggestions?</TD></TR></TABLE>
maybe your battery isnt good.. or your starter. But these are just suggestions from my guesses
Old Oct 26, 2003 | 05:17 PM
HatchBox's Avatar
Skoobie no more...
is it throwing any codes?
Old Oct 27, 2003 | 04:12 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (ind3ciso)
No codes! Could I have messed up when I did the DPFI to MPFI change. Maybe cylinder sensor wiring is wrong?
Old Oct 27, 2003 | 04:57 PM
HatchBox's Avatar
Skoobie no more...
there is 2 wires on the dizzy that are both white (well one was a diff color but it always fades...mabybe you got them switched. the car will crank but wont start
Old Oct 29, 2003 | 04:01 PM
RobbieG35's Avatar
12 Years Strong
Switched em both and nothing
Active EF
Feb 21, 2015 08:56 PM
jayc
23
Nov 3, 2009 07:02 PM
GasDreamz
16
May 6, 2009 05:21 PM
jefferym7901
May 21, 2006 02:50 PM
.ShawnD.
Aug 31, 2002 02:57 PM
