What head for VX engine?
Old Oct 25, 2003 | 07:47 AM
1990hondaHF's Avatar
Default What head for VX engine?
I did a search but mostly what I found was info about swapping vtec heads onto SI engines...not much about swapping vtec heads onto VX engines.....am I looking in the wrong place?
Old Oct 25, 2003 | 07:52 AM
SICKSOLSI's Avatar
Default Re: What head for VX engine? (1990hondaHF)
Its not worth swapping heads onto a vx engine because your compression will be lowered..this is due to the 7.05mm piston dishes...
Old Oct 25, 2003 | 07:53 AM
Johnny Tran's Avatar
it 'may' be a bigger deal than you think. Although I have not fully investigated the possibilites, you are going from a 'three valve' configuration to a four. I understand the pistons are almost dished, but do your homework before you just throw all that stuff on.
Old Oct 25, 2003 | 07:58 AM
SICKSOLSI's Avatar
Default Re: What head for VX engine? (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">it 'may' be a bigger deal than you think. Although I have not fully investigated the possibilites, you are going from a 'three valve' configuration to a four. I understand the pistons are almost dished, but do your homework before you just throw all that stuff on.
why would it matter about going from the 3 valve system to the 4 valve? its not like your using the same head....the only problem lies in the pistons ive done a fair amount of research on this because when i had my vx i wanted to do the same
https://honda-tech.com/zero...age=4
http://www.heeltoeauto.com/dseries/dseries1.html
Old Oct 25, 2003 | 08:02 AM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">I did a search but mostly what I found was info about swapping vtec heads onto SI engines...not much about swapping vtec heads onto VX engines.....am I looking in the wrong place? </TD></TR></TABLE>
Both the Si and VX already have VTEC heads. You can put the Si head on the VX and have a mini-me. I'm not too familiar with the mini-me but I believe that is a common one.
Modified by JMU1337 at 12:15 PM 10/25/2003
Old Oct 25, 2003 | 08:09 AM
RedHackBatch's Avatar
i suggest a vx head on the vx motor
Old Oct 25, 2003 | 02:03 PM
BatuKing's Avatar
Default Re: What head for VX engine? (RedHackBatch)
Whoa.. how can you put a Si head on a VX block you will get a CEL for not having a EGR attached to it.. your best bet is to ditch that block and swap it. I myself am rebuilding a D16Z6 and using that instead of a VX motor
Old Oct 25, 2003 | 03:15 PM
Default Re: What head for VX engine? (BatuKing)
No CEL if you use a P28....who would use a p07 anyway?
Old Oct 25, 2003 | 06:53 PM
SICKSOLSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">No CEL if you use a P28....who would use a p07 anyway?</TD></TR></TABLE>
Due to the 5 wire oxygen sensor
Old Oct 25, 2003 | 07:16 PM
Default Re: What head for VX engine? (95excoupeMT)
5 wire...ah the P28 uses a 4 wire....the VX uses a 5 wire....
randerson0248
12
Sep 29, 2021 08:45 PM
flaco06114
Sep 23, 2009 04:12 PM
rice is nice
Aug 20, 2008 04:46 AM
Bense
12
Mar 27, 2006 08:47 AM
agordon
Nov 24, 2005 10:58 PM
