rubbin the fenders
Old Oct 25, 2003 | 07:41 AM
GhettoR's Avatar
Default rubbin the fenders
New to the forum and need some help. I have a 92 SI, rolling on Skunk2 coilovers and kyb struts. What is an acceptable height and how do I stop the front wheels from rubbin the fenders.
Old Oct 25, 2003 | 08:21 AM
MrHeeltoe's Avatar
Default Re: rubbin the fenders (Nobosswanted)
Trial and error I havet to say....you'll just have to adjust and drive...depending on your rims, you should be able to get a nice slam on
Old Oct 25, 2003 | 08:32 AM
u0f's Avatar
u0f
to stop the rubbing, raise it up. acceptable height is one finger gap between the tire and fender.
Old Oct 25, 2003 | 08:41 AM
4nmusle's Avatar
Default Re: rubbin the fenders (u0f)
bend the inner fender in some
Old Oct 25, 2003 | 08:48 AM
egizzle8
Guest
Posts: n/a
Default Re: rubbin the fenders (4nmusle)
Had the same problem last weekend when I installed my AGX's and Tein S-Techs but gave it a nice drop and handles nice with not having swaybars yet(it's a dx). Took a hammer to the fender and had to give it a couple of knocks on the inside.
Old Oct 27, 2003 | 04:05 PM
GhettoR's Avatar
Default Re: rubbin the fenders (egizzle6)
Rolling on carbon spec-vs and kuhmos, this rubbing only happens when I go around corners. Sits nice but hates tight turns , will try that finger thing though.
Thanks
Old Oct 27, 2003 | 04:07 PM
Archidictus's Avatar
Unceasing Measure
I've got a 1993 Si with KYBAGX's and Tein S-Techs and it doesn't rub even a little at full wheel lock...I'm also running the stock 14 inch steelies though.
Old Oct 27, 2003 | 04:08 PM
TrickHonda98's Avatar
Default Re: rubbin the fenders (Archidictus)
roll out your fenders with a baseball bat or pipe.
nanisi
Mar 20, 2014 05:52 AM
alacard
Dec 8, 2009 05:29 AM
1200 Hobos
Suspension & Brakes
Nov 16, 2009 07:58 AM
maldini76
Mar 18, 2005 04:00 PM
