how to tell sleeves cracked???
Old Oct 24, 2003 | 05:59 PM
turbociv's Avatar
Default how to tell sleeves cracked???
The engine is a b20vtec and recently my crowers broke into 4 peices and screwed alot of **** up. I replaced all of the exuast valves and lapped them into place and when I went to start my engine, it ran fine for a few seconds and then I heard like a some sort of pressureized or zipping sound( hard to explain) and 2 seconds later my idle shot up and white smoke started to poor from my tail pipe. I noticed that after installing the head when I would manualy turn over the engine I would here a coolant girgle noise. I pulled every spark plug out and only inserted one ata time and manually cranked to listen for the noise and it was there every time. I was trying to pinpoint the blown cylinder gasket. I inspected the block carefully and didn't notice any thing wrong or anything that would catch the eye. Engine oil looked clean but I had a ton of crankase pressure after turning off the engine It also smelled really sweet. Also when I started the engine I took off the coolant cap and it looked like a wave pool.
I am thinking that the problem is somewhere in the head but where??? I took a straight edge and the block deck looked pretty straight.
2 head gaskets and same problem. WTF. Im pissed and confused all at once.
Old Oct 24, 2003 | 07:30 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: how to tell sleeves cracked??? (turbociv)
try compression check/leakdown.
Old Oct 24, 2003 | 10:14 PM
turbociv's Avatar
when the head was on the engine I did a compression test but the motor was cold and not realy accurate to go by. Unfortuneatly I do not have access to a leak down tester where the car is(no air) so I couldnt check that either.
packrat79
Classic Hondas
Oct 1, 2015 08:27 AM
sf89lx
Mar 6, 2008 02:16 AM
filtereds0ul
Jan 27, 2004 11:23 AM
