FS: 90 civic si hatch, black, b16, jdm, so-cali recently smogged
EDIT 9/23
trades
new price 2200
pics added at bottom of page
feb/04 registered until feb05
there is no rust or large dents, sun roof works
c's short shifter
battery is in the right side of the hatch
new distributor cap and rotor 8/04- igniter
no heater
no a/c
gutted rear seats and panels and rear wiper, but have some parts.
interior-
autopower roll bar, bolted on
momo steering wheel and hub, foam
srr red 50 mm steering wheel spacer
gutted rear
exterior-
7/04- jdm bumper got jacked, have flat black 89 bumper with home depot lip and stock amber turn signal lights.
ef9 front end
stock rear bumper cut on right side where it used to have right exit exhaust
8 si hubcaps
4 99 civic ex hubcaps
suspension-
crx si rear discs
suspension techniques springs
tokico illuminas in the front
tokico blues in the rear
06/03new rotors
06/03new axxis ultimate pads in the front
front strut bar
rear upper strut bar
rear lower tie bar
engine-
b16a
ctr cams
skunk2 cam gears
greedy sp with tip cut off(still have the tip)
hollowed cat
integra ls intake arm and cone filter
notes-
sunroof has a crack, its from the outside, crack cant be felt from the inside and does not leak, has looked the same since I've owned the car.
no large dents and no rust
runs fine, I went to las vegas and back *edit* 4* times with no problems, around 800miles round trip each time
hole in driver seat, left bolster, like most si seats... masking taped...
extra parts-
extra ef9 sir passenger side headlight
front passenger side tokico blue
stock shocks
ef9 sidemarkers
extra ef9 clear corners
maintenance I have done since owning the car
oil changes every 3months or 2000-2500miles(I get free oil)
09/03 new wheel bearings in the front
05/04 new ignighter
09/04 new cap/rotor/ oil change
EDIT 9/15/04
JDM bridgestone super rap front "white" wheels not included
JDM REAR BUMPER AND OTHER PARTS REMOVED TO LOWER PRICE
Modified by NINJASPY at 2:03 PM 9/23/2004
Modified by NINJASPY at 2:05 PM 9/23/2004
Modified by NINJASPY at 12:04 AM 9/30/2004
trades
new price 2200
c's short shifter
no heater
no a/c
interior-
gutted rear
exterior-
ef9 front end
8 si hubcaps
suspension-
crx si rear discs
06/03new rotors
front strut bar
rear lower tie bar
engine-
b16a
ctr cams
skunk2 cam gears
hollowed cat
notes-
extra parts-
stock shocks
ef9 sidemarkers
05/04 new ignighter
EDIT 9/15/04
pics up this weekend...
I just got some weird vibration now
, its probably the axles going out....
**it was the wheel bearings, fixed
Modified by NINJASPY at 11:49 PM 3/15/2004
, its probably the axles going out....**it was the wheel bearings, fixed
rear upper portion of seats installed for faux purposes to elude the police
, but rear side panels and rear bottom of seat removed... have them if you want to put them back in... also have rear trunk cover.
bump
, but rear side panels and rear bottom of seat removed... have them if you want to put them back in... also have rear trunk cover.bump
DynoMite!!!!!
