Mini Me.. 1.5 Liter?
What is your guys opinion on Mini-Me D16Z6 with the DX block? Can the DX handle the 130HP? I searched throughout that big Mini-Me post but didn't find anything about a DX block. Thanks..
Why would wiring be an issue using a DX block? Take out the Oil Jet, use my Si / HF wiring harness I have laying around with the Si distributor..
Anyone else?
Anyone else?
i did it and it runs great. make sure you get an adjustable cam gear. the z6 head will be off 1/2 tooth. your going to have to convert to mpfi too. search mpfi and you should come up with a lot of good info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">yes it will work
in my case... as my experience i loved it and hated it.....
ran good til i spun a bearing
but only lasted me 1000 miles and died on the dyno</TD></TR></TABLE>
Same thing happened to me but on a d16y7 block with a d16y8 head. I wonder why it spun a bearing..
Sounds kinda iffy to me now... Spun bearings eh? Did you guys beat the hell out of the motors or what? I need this motor to last more than 1,000 miles that's for sure.
As long as it's reliable I don't care.. We'll see whathappens. I am talking about the EF CRX / Civic DX block if anyone isn't sure.
i spun i tbaout 3 weeks ago
i already have a full D16Z6 now... i been working 65 hrs a week and havent had time to go and open the D15 block to find the reason qhy it spun it..... but i wil update
hmm when i start my car cold it will stutter to about 1000rpm, the oil light will blink one more time than its supposed too. and then the car runs great. i change the oil every 3k miles and have had my mini-me for a littleover 1k miles. oh yea, i take it up to 7500 daily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">spun bearing = lack of oiling + overrev.</TD></TR></TABLE>
true
but thats the reason....
now u need to find the cause
wich its either a bad oil pump, bad oil, bad clearances on the bearings, or clogged lines inside the crank and other passages
true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey »</TD></TR><TR><TD CLASS="quote">I never overreved my mini me swap and it still spun a bearing.</TD></TR></TABLE>
exactly
my D15B mini me had brand new bearings..... 2 oil changes under 900 miles, ran good, after installing a cam, and being dynoed..... it spun it on the dyno... and never paassed 7200
exactly
exactly
my D15B mini me had brand new bearings..... 2 oil changes under 900 miles, ran good, after installing a cam, and being dynoed..... it spun it on the dyno... and never paassed 7200</TD></TR></TABLE>
Thats really weird...I hope the B7 blocks are stronger than the B2's
At least I have a spare Z6 motor sitting in my garage
exactly
im running a d15 block with a y8 head. it runs just fine. my d16z6 block spun a bearing and i am almost done rebuilding it. so just goes to show that you can spin bearings in both blocks.
exactly
Didn't you have oil pressure problems?? I seem to remember a post you created about it.
exactly
RicedREX
Nov 8, 2003 07:39 AM
firstgenrex
Sep 29, 2003 01:37 PM
