Bseries - Throttle cable - Rig
Old Oct 24, 2003 | 03:39 PM
CunninLynguist's Avatar
Default Bseries - Throttle cable - Rig
Can i get an explaination or some pics on how you guys riggd your civic throttle cables to fit your bseries swaps.
Old Oct 24, 2003 | 05:41 PM
Default Re: Bseries - Throttle cable - Rig (Scot project)
Old Oct 24, 2003 | 07:02 PM
EG TYPE-R's Avatar
i just bought the type-r cable and bracket and that did the trick but if your asking to use the stock one i dont know
Old Oct 24, 2003 | 07:09 PM
B18C1EKhb's Avatar
Default Re: Bseries - Throttle cable - Rig (EG TYPE-R)
nah i dont think it works in most cases you will usually have to buy a new one, i got the gsr for my gsr swap
Old Oct 25, 2003 | 08:24 AM
dwnthehatch's Avatar
Default Re: Bseries - Throttle cable - Rig (B18C1EKhb)
I used a 98 GSR throttle cable bracket on the firewall. It bolted right up.
Old Oct 25, 2003 | 08:27 AM
SignfcntOthr's Avatar
Default Re: Bseries - Throttle cable - Rig (dwnthehatch)
I used a throttle cable off of a '96 LS on my B16 powered 93 CX, bolted right up.
Old Oct 25, 2003 | 08:36 AM
B.'s Avatar
B.
400 HP Club
Default Re: Bseries - Throttle cable - Rig (SignfcntOthr)
this is the best pic I have.... hope this helps.. I just machined a bracket at my buddies shop, sand blasted it and powder coated it.
Old Oct 25, 2003 | 08:39 AM
Archidictus's Avatar
Unceasing Measure
I have 100% never had a problem with making a stock civic throttle cable bolt up to any B-series swap...what is everyone else doing differently?
Old Oct 25, 2003 | 08:45 AM
B.'s Avatar
B.
400 HP Club
Default Re: (Archidictus)
I had to make the bracket longer, otherwise the throttle cable came up to short with the stock mounting bracket.
Old Oct 25, 2003 | 08:48 AM
deeksmooth's Avatar
ditto... ITR throttle cable for my ITR swap into 99 EK... inlinefour has OEM cables.
Old Oct 25, 2003 | 09:03 AM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I have 100% never had a problem with making a stock civic throttle cable bolt up to any B-series swap...what is everyone else doing differently?</TD></TR></TABLE>
The question is, what are you doing differently? My D series bracket was off by a few inches.
Old Oct 25, 2003 | 09:05 AM
Unceasing Measure
I think I moved the stock bracket to a different location in all previous circumstances. Creativity &gt; spending money I don't have
Old Oct 25, 2003 | 09:19 AM
aw1234dude's Avatar
Ha ha yeah, I moved my bracket too....because im a cheap *****.
Old Oct 25, 2003 | 11:46 AM
Default Re: (aw1234dude)
aw1234dude: Thats the stock civic cable?
Also what kind of car is that.
Old Oct 25, 2003 | 11:50 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I think I moved the stock bracket to a different location in all previous circumstances. Creativity &gt; spending money I don't have </TD></TR></TABLE>
Yup, or ends up saving a bunch of time waiting for parts to come in. I had to custom make a bracket for my y7 throttle cable on my y8 (using the y7 throttle cable braket).
Old Oct 25, 2003 | 11:58 AM
boostedcivicsir's Avatar
Mr. Badwrench
order it before you swap, and it should be in when you are ready.
a new throttle cable is like 15 bucks. get the right one.
Old Oct 25, 2003 | 01:12 PM
tangb2023
Guest
Posts: n/a
i cutted the metal wire that wraps around the cable itself, so it can extend and move the bracket a little on the mani.. ghetto but it works fine
Old Oct 25, 2003 | 01:57 PM
Unceasing Measure
Default Re: Bseries - Throttle cable - Rig (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">order it before you swap, and it should be in when you are ready.
Do you know how much Taco Bell $15 buys?!?!?!
Old Oct 25, 2003 | 04:44 PM
aw1234dude's Avatar
Default Re: (Scot project)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot project &raquo;</TD></TR><TR><TD CLASS="quote">aw1234dude: Thats the stock civic cable?
Also what kind of car is that.</TD></TR></TABLE>
Yeah, that was my stock cable on my 97 civic hatch. I just used a piece of half inch steel and made a bracket that moved the throttle cable holder over to the left an inch or so. It took all of about 10 minutes to do. Ive checked and it also opens up the throttle body plate all the way.
Old Oct 25, 2003 | 05:49 PM
Mr. Badwrench
Default Re: Bseries - Throttle cable - Rig (Archidictus)
Do you know how much Taco Bell $15 buys?!?!?! </TD></TR></TABLE>
hey i am sorry but if it makes my life a little easier, and i like the cleaner look.
Old Oct 25, 2003 | 07:56 PM
dwnthehatch - Is that only the bracket you are using? Stock civic cable?
Old Oct 26, 2003 | 08:31 AM
The stock cable fit in that bracket but was a little loose. I only changed it to the b-series cable because it came with the swap.
Old Oct 26, 2003 | 09:04 AM
slowdx's Avatar
same here mine works fine
Old Oct 26, 2003 | 09:38 AM
SlippylesKB's Avatar
Default Re: (slowdx)
I have mine ziptied to my strut bar.... it's ghetto.
Old Oct 26, 2003 | 10:10 AM
thehatchninja's Avatar
Default Re: (SlippylesKB)
zip ties work wonders....at one point they were holding several parts of my car together....maybe ghetto, but as long as it runs right i don't care.
