Distributor
That depends entirely on what ECU you have.
if you have an OBD0 ECU like a PR3 or PWO then you will need a JDM B16 distributor. Or a CRX Si or HF distributor. It won't bolt right up but it will run the engine no problem.
if you have a OBD0 to OBD1 ECU convertion, then you need an OBD1 or OBD2 ECU. The OBD2 ECU will have to be repinned to make it work, but it will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazykiwi »</TD></TR><TR><TD CLASS="quote">98</TD></TR></TABLE>
What obd is it.
What obd is it.
89hatcher
Jun 5, 2006 02:01 AM
DevineCRX
Nov 26, 2003 06:40 AM
