HELP ME MAKE MY CAR FASTER!!!!
Old Oct 24, 2003 | 08:14 AM
classciv's Avatar
Default HELP ME MAKE MY CAR FASTER!!!!
just bought a crx with b20, although it is very quick i am already used to the speed and would like to increase the quickness of it, any segestions??
Old Oct 24, 2003 | 08:16 AM
EF_LSVtec's Avatar
Default Re: HELP ME MAKE MY CAR FASTER!!!! (classciv)
vtec head...or do a headwork on your current one...port & polish, cams, intake, header...tuning.
Check the all motor forum, I'm sure there are a lot of topics regarding upgrading your B20.
Limited S.L.I.P.'s Avatar
1. cr/vtec
2. search. try searching cr/vtec, cr vtec, or b20/vtec.
Old Oct 24, 2003 | 08:17 AM
Default Re: HELP ME MAKE MY CAR FASTER!!!! (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">vtec head...or do a headwork on your current one...port & polish, cams, intake, header...tuning.</TD></TR></TABLE>doh.. you beat me to it..
Old Oct 24, 2003 | 10:14 AM
classciv's Avatar
Default Re: HELP ME MAKE MY CAR FASTER!!!! (Limited S.L.I.P.)
how hard is it to do a vtech head swap?
Old Oct 24, 2003 | 10:36 AM
Grease Monkey's Avatar
vtec...
do a search. It really isnt as hard as it seems
Old Oct 24, 2003 | 10:50 AM
DsMWookie's Avatar
Default Re: HELP ME MAKE MY CAR FASTER!!!! (Grease Monkey)
Buy a supercharger or turbo bolt it on and roll out...friend had a b20 greddy turbo hatch and that **** was ******* fast...he ran bout 10-12lbs ^^
Old Oct 24, 2003 | 11:04 AM
roadawg's Avatar
b16 head, stage 3 cams and valvetrain, ITR intake manifold, JG throttle body, 12:1 pistons, thin head gasket, good header, 2.5 " exhaust, straight through muffler and BAM, 12's no prob
Old Oct 24, 2003 | 11:32 AM
classciv's Avatar
Default Re: HELP ME MAKE MY CAR FASTER!!!! (SiRWanabe)
doesnt sound too bad, i have never done any work on an engine before, so i would probly need walked through it, how much should it all cost me?
Old Oct 24, 2003 | 12:49 PM
turboZChatch's Avatar
turbo
Old Oct 24, 2003 | 01:32 PM
classciv's Avatar
Default Re: HELP ME MAKE MY CAR FASTER!!!! (turboZChatch)
im not sure if i would go with a turbo or not, every one i have riden in has a a bit of a lag time on getting going. i like a real quick snap off the start.
Old Oct 24, 2003 | 02:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">im not sure if i would go with a turbo or not, every one i have riden in has a a bit of a lag time on getting going. i like a real quick snap off the start.</TD></TR></TABLE>
That lag time is called turbo lag and you wont really get it if you use the right turbo like a t3 or even a t3/t4 it will spool up nice and fast thats your best bet b20 vtec in my opinion is cool but a ticking time bomb(thats a whole nother topic) good luck with whatever you choose
Old Oct 25, 2003 | 10:23 AM
AfroThunderEF9's Avatar
ummm................... http://www.b20vtec.com, i did b20 vtec and my car pulls daym hard now and I just Have sleeves 11.5 comp je pistons, ctr cams and I pull about 190-200 whp with a vafc and I love the damn thing had it for aobut 6 months still runnin strong
Old Oct 25, 2003 | 10:49 AM
91civicDXdude's Avatar
keep the non VTEC head and use the power band Honda has craftfully given to you, (and that the stock bottom end will support) which is lower rpm.
get some cams, light port work, bolt ons, you should be screaming.
Old Oct 25, 2003 | 11:06 AM
I fjhlllllllllllkvu's Avatar
Default Re: (91civicDXdude)
Make it B20B-VTEC 180+WHP
Get a B16A cabel tranny J1 Y1 S1 shoter gering make Shore it not a LS tranny,
Next B16A Head complet make shore it's in good cond,
PR3 ecu non OBD b16A ecu gen1
CTR intake & ITR exhuste cam's ITR I.M. wet T.B. and DC 4to1 Headers wet 2.5 colt, and some Bolt ones mide to High 13.s I seen this set up runing 13.60 and some 13.50 ALL on street tires in your CRX
Old Oct 25, 2003 | 11:43 AM
^^ yeah dont forget about totally rebuilding the internals. with low *** compression, you'd be lucky to get 140whp from a stock b20 vtec.
Hell, if you're going that route, you might as well buy a dart b20 block.
Old Oct 25, 2003 | 08:35 PM
Eresuncabron's Avatar
**** all that **** and buy a ******* stock ITR engine
Old Oct 25, 2003 | 11:06 PM
Starbucks_91b16acrx's Avatar
Default Re: (Eresuncabron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron &raquo;</TD></TR><TR><TD CLASS="quote">**** all that **** and buy a ******* stock ITR engine</TD></TR></TABLE>
werd~!
Old Oct 25, 2003 | 11:10 PM
JenniferDC5's Avatar
sell it and buy a crx si
Old Oct 26, 2003 | 08:38 AM
Default Re: HELP ME MAKE MY CAR FASTER!!!! (JenniferEF9)
what kinda quarter do you run with ur car now
si's run high 15's
Old Oct 26, 2003 | 09:53 AM
R6Boy69's Avatar
Thats what I did...
Old Oct 26, 2003 | 11:02 AM
Default Re: (crXBoy69)
I will SMOK a CRX, 88 HF wet a ITR motor HAAAA any day wast of $$$$$ $5,000 for a swap not wore it to Me. You will only make 174WHP wet Bolt ones and Run 13.70 on stret tires, B20Vtec make 180+whp If U now how to Build Motor ,,
B20b vtec if you do not build the short block good for Mide rang power!
Bore out a LS block to 84.5 you have 2.0L ls short block has the same crank and rod's as a b20b/Z. Anywa Type R motor want be That Fast
Old Oct 26, 2003 | 11:05 AM
sporkcrx's Avatar
Default Re: (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">I will SMOK a CRX, 88 HF wet a ITR motor HAAAA any day wast of $$$$$ $5,000 for a swap not wore it to Me. You will only make 174WHP wet Bolt ones and Run 13.70 on stret tires, B20Vtec make 180+whp If U now how to Build Motor ,,
_______
STAY ALL MOTOR!</TD></TR></TABLE>
STAY IN SCHOOL!
Old Oct 26, 2003 | 11:10 AM
Default Re: (sporkcrx)
COME to HALXXXXX L aod get
poped ho
Old Oct 26, 2003 | 01:40 PM
slooogsr's Avatar
a nice turbo kit would make a b20rex sik in my opinion............ do the turbo route!
