Powerband on B18B?
Old Oct 24, 2003 | 07:55 AM
joshmarlette's Avatar
Default Powerband on B18B?
What is the powerband on the B18B? Where am I making the most torque and where am I lacking the most.
Old Oct 24, 2003 | 08:01 AM
StyleTEG's Avatar
Default Re: Powerband on B18B? (joshmarlette)
Most torque between 5 - 6k rpm
lacking between 6k - redline.
Old Oct 24, 2003 | 08:03 AM
Default Re: Powerband on B18B? (StyleTEG)
So low end torque is also a problem then?
Old Oct 24, 2003 | 08:06 AM
DUCK COMMANDER's Avatar
there is no power.
the most grunt i find as around 3-5 k after that it falls on its face and there is no low end
Old Oct 24, 2003 | 08:59 AM
Audipwr1's Avatar
Default Re: Powerband on B18B? (DUCK COMMANDER)
unless you put it in a 1900 lb car, then itll burn rubber through 3 gears
Old Oct 24, 2003 | 10:55 AM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmarlette &raquo;</TD></TR><TR><TD CLASS="quote">So low end torque is also a problem then?</TD></TR></TABLE>
low end torque is not bad for a honda. It has higher displacement than a B18C1 due to the stroke.
Its about as good as you can get out of a B series minus the B20.
kev8alot
Jan 23, 2014 06:38 PM
DA is best
Aug 11, 2011 12:33 PM
DB1_559
Nov 26, 2006 01:39 PM
b18bme
Apr 7, 2004 11:51 AM
