Throttle body Question
Old Oct 24, 2003 | 06:51 AM
Globalundrground's Avatar
Default Throttle body Question
Does anyone make a bigger throttle body for Accords??? i did a search and really coudn't find anything..
Old Oct 24, 2003 | 07:12 AM
v4lu3s's Avatar
RTFM
anything that will fit an h22a will bolt on to an f22/23 manifold.
unleses you are running a lot of boost or serious all motor setup its gonna be a waste of time and money though since the stock throttle body is well sized and not a choke point for a mild engine or one with bolt ons.
Old Oct 24, 2003 | 07:35 AM
Drag-On23's Avatar
Default Re: Throttle body Question (Globalundrground)
If you want an overbored TB, you can get it done at a motor shop like Gude and JG Engine Dynamics just to name a couple.
Old Oct 24, 2003 | 07:43 AM
Crono139's Avatar
Get an aftermarket TB made for the H22/H23.
Old Oct 24, 2003 | 08:05 AM
Default Re: Throttle body Question (Drag-On23)
I will be running a lot of boost.. My head and Intake Manifold is a BCE and Bill needs to know what size Throttle body im using so he can match opening.. So that's why i wanted to know if i could get a bigger one.. So since they have a after market H22's out , Map sensor, and Fast idle valve are the same for the both so there shouldn't be a issue for the components. so basically It's a direct bolt on..
thanks
Do you know of any Aftermarket Company that makes them?
Matthew B
Modified by Globalundrground at 5:16 PM 10/24/2003
f22a1 ftw
Jun 7, 2012 09:51 AM
perseverance
Welding / Fabrication
Apr 25, 2010 12:22 PM
2mchbst
Apr 13, 2009 04:34 PM
ssr_h22
Apr 23, 2005 07:53 AM
gavhowe
Apr 22, 2002 07:18 AM
