Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
NASA Rule Clarification
Old Oct 24, 2003 | 06:15 AM
Solo2Cvc's Avatar
Default NASA Rule Clarification
I just completed my race tech form when I came across "head restraint". The NASA GCR states the rule as follows:
15.5.21 - Head Restraint - A head restraint must be used to prevent whiplash. The head restraint must have a minimum area of thirty-six (36) square inches and be padded with a non-resilient material such as Ethafoam or Ensolite with a minimum thickness of one (1) inch.
Does this rule refer to the racing seat or is this a seperate device? The only whiplash protection the racing seat has is the fact the the seat back extends higher than the driver's head (as do most racing seats). Do I have to buy something extra?
Old Oct 24, 2003 | 06:22 AM
.RJ's Avatar
.RJ
Default Re: NASA Rule Clarification (Solo2Cvc)
I use this:
http://www.ogracing.com/eshop/...ake=1
Old Oct 24, 2003 | 06:58 AM
Solo2Cvc's Avatar
Default Re: NASA Rule Clarification (.RJ)
NASA considers that a neck collar support as per rule 15.16.8 and is "strongly recommended".
Old Oct 24, 2003 | 08:24 AM
Crack Monkey's Avatar
They are refering to the seat. If the seat back is tall (as is the case with all new SFI/FIA seats), then you're ok. If it's a short bucket (common on vintage cars), you need a headrest/pad installed above the seat back so your neck can't whip back.
Old Oct 24, 2003 | 08:25 AM
kedwards's Avatar
I always assumed that the head restraint requirement was if your seat didn't already have one.
My really old race car has a racing seat without a headrest, so there is a padded piece of plywood connected to a brace to the rollbar. It looks to be around 36 square inches or so.
Old Oct 24, 2003 | 10:44 AM
Solo2Cvc's Avatar
Sounds to me like I am good to go then. Thanks for the help.
YeahRight!
May 29, 2007 07:02 AM
Buttcrack
Feb 18, 2005 07:41 AM
Greyout
Dec 24, 2003 11:16 AM
advanracing62
35
Sep 23, 2002 08:53 AM
