Temp for "cooking" tail lights?
Old Oct 24, 2003 | 06:02 AM
CHK4TIX's Avatar
Default Temp for "cooking" tail lights?
Ok, i thought i saw it on here some time ago, but i cant find it using the search. What is the oven temp used for heating tail lights to remove the lenses? If someone knows any other information that would help me in my quest it would be appreciated.
Old Oct 24, 2003 | 06:10 AM
Sephro's Avatar
Default Re: Temp for "cooking" tail lights? (CHK4TIX)
IIRC it was 350. I don't think it really matters just make sure you don't melt them just the glue.
May want to try posting in the appearance forum.
NTPOG has a different way now. http://www.ntpog.org/mods/fift...shtml
Old Oct 24, 2003 | 06:47 AM
CHK4TIX's Avatar
Default Re: Temp for "cooking" tail lights? (Sephro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">IIRC it was 350. I don't think it really matters just make sure you don't melt them just the glue.
NTPOG has a different way now. http://www.ntpog.org/mods/fift...shtml </TD></TR></TABLE>
thats good info, but i actually do need to remove the lense. thanks
Old Oct 24, 2003 | 07:28 AM
Archidictus's Avatar
Unceasing Measure
350 for 12 minutes or 400 for 9. I did 400 for 9 on my buddy's RSX-S tails and it came out great.
Old Oct 24, 2003 | 07:31 AM
CHK4TIX's Avatar
Default Re: Temp for "cooking" tail lights? (Archidictus)
thanks, did you have to do anything special to get tem back together?
Old Oct 24, 2003 | 07:52 AM
SLeePeR012's Avatar
I used 250 for 5 mins twice for each housing.
I didnt wanna get it too hot and melt it. Ive seen it happen.
Old Oct 24, 2003 | 08:12 AM
CHK4TIX's Avatar
Default Re: Temp for "cooking" tail lights? (SLeePeR012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 &raquo;</TD></TR><TR><TD CLASS="quote">I used 250 for 5 mins twice for each housing.
I didnt wanna get it too hot and melt it. Ive seen it happen.</TD></TR></TABLE>
so was that twice in a row or was it twice once to get it off and once to get them back on?
Old Oct 24, 2003 | 09:01 AM
Unceasing Measure
I put them back together and put them back in the oven for 10 minutes on 400. Took em out, pressed em together real well, silicon caulked em and let them sit for 30 minutes before I put them back on. Unfortunately, I melted the corner of on of the rear tabs (unseen and unimportant) so I can't claim a "perfect DIY black housing" project.
Old Oct 24, 2003 | 10:38 AM
CHK4TIX's Avatar
ok, thanks for the info, i will be doing mine tonight. hopefully all goes well
Old Oct 24, 2003 | 10:44 AM
iam7head's Avatar
400 five min, same formula i used on all five headlight i painted
dont really pry it out with alot of force, the heat should soften the silicone and it should easily come out, if you pry the len too hard, it will deform by a little and it will not fit perfectly.
anyway, get some silicone(grey) in autozone and reseal them back the same fashion you take them off
Old Oct 24, 2003 | 10:03 PM
SLeePeR012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">
so was that twice in a row or was it twice once to get it off and once to get them back on?</TD></TR></TABLE>
twice to pry it, just in case it dont melt
Old Oct 24, 2003 | 10:11 PM
Echo7847's Avatar
I only did mine at around 205 for about 10 minutes and it worked perfectly fine for me.
Old Oct 25, 2003 | 12:08 AM
lol at u's Avatar
I used a heatgun to seperate my taillights. worked like a charm.
Old Oct 28, 2003 | 07:23 AM
CHK4TIX's Avatar
Default Re: (b20 DA9)
well, i tried it and i total destroyed one of them, but i think i figured out now. so as soon as i get my replacement tails, i think they will work out great
Old Oct 28, 2003 | 07:39 AM
Echo7847's Avatar
Default Re: (CHK4TIX)
LOL what happened??
Old Oct 28, 2003 | 11:00 AM
CHK4TIX's Avatar
Default Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">LOL what happened??</TD></TR></TABLE>
well, on the first light the removal, everything went as planned i did 300 for 7 min. then for some reason i decided to try 350 for 5 min for the second one. well the problem comes along when i forget to set the timer and when i realized it, it had been who knows how many minutes. . Anyways, the lens was only slightly melted when i caught it. So i took it apart anyways.
Then when i was putting them back together it didn't heat them up first and cracked the good lens just a tiny bit. So i decided to practice warming them up a bit before putting them back together, so i was going to do the same 300 for a few minutes just to warm it up. When the timer when off i found a melted tail light because i forgot to turn the temp back down from 350.
BUT i was able to use the other one to verify temps that would work with out problems. so i should be able to do it right next time.
Old Oct 28, 2003 | 11:13 AM
TRE_'s Avatar
i used a heatgun to seperate my taillights... i'm afraid i'd melt them in the oven...
danieldc4
Dec 31, 2006 08:09 AM
pimpcivicex
10
Jun 10, 2004 07:25 PM
99fbpem1
Jun 29, 2003 03:42 PM
99fbpem1
Jun 4, 2003 12:30 AM
krnboixshawn
May 22, 2003 03:42 AM
