b16 crx fuel rail question
Bout to buy a dc fuel rail.. are they universal on bseries? Was used on a 1.8 but getting it for my b16.. is there a way to see if it will work or not frmo the outside? Like will it not mount up if it's only for 1.8? Thanks.
No, they are not universal.
The spacing between the injectors is the same, but the way they mount to the
manifold varies from manifold to manifold. you might need to add washers or spacers to make it work. It's hard to tell exactly what you'll have to do. You might get lucky and have it fit right in.
