revving up to 9000 or more
what is the cheapest way i can rev up to 9000 without damaging anything?? i was thinking, itr inner springs and maybe ti retainers and ctr cams($450 upgrade all together). any thoughts?? its for a stock gsr motor. will the vavles float b4 9000 with those things in??. what will the gsr revv up to b4 float begans??
or what the best upgrade to do??
hoping to see some 13s, is it possible
well, i just wanted to know the best way to rev to 9000 makeing power still. what the cheapest cams and vavletrain should i use to do that. best bang for the buck. please lists parts so i know what i can choose from. i kinda know that the setup i put down earlier was not going to make power up there but i was going to upgrade the cams again later. from gsr cams to ctr cams first then maybe to jun3.
any help for best bang from little bucks????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alllgo »</TD></TR><TR><TD CLASS="quote">what is the cheapest way i can rev up to 9000 </TD></TR></TABLE>
Motorcycle , only thing you'd be hurting would be yourself if u couldnt control it.
But as posted, if u are not making power in that RPM range there is no purpose to rev that high......
Acura97GSR
Jul 12, 2001 11:23 PM
