vafc on obd-0 b16a
does the vafc work work well on obd-0 b16a im hearing not so reliable rumors that it doesnt work well with obd-0 only obd-1 and 2 ?
is this true? if so why.. i asked around work and they were not sure either..
thanks again
brian
thanks again
brian
There should be NO REASON for the Vafc to work "better" whether it be OBD1, OBD1, or OBD2.
The Vafc is wired "inline" with the MAP sensor ( to alter fuel maps ) and the Vtec Pressure switch and Solenoid. ( to alter Vtec engagement ).
I've installed them in all types and if done correctly, there should be no issues no matter what version OBD you have.
I8ayellowcrayon
Jan 9, 2005 08:44 PM
