92 teg seats in 91hb
has anyone put 91-92 teg seats in their hatch.. the crx seats wont bolt to hb rails my seats are in crooked..lol i need new seats.. will the 91-92 tegs work.. thanks
brian
brian
yes they will work.
i had the same problem.. crx seats wouldn't fit. how i got the integra ones to fit (you might find another way that works) is first, i cut off the front brackets on both the teg and civic seats and bolted the civic front brackets onto the teg rails with two bolts on each side. then on the rear, on the inside rail (the flat one) i had to hog the hole out a little bit so i could adjust the seat around until it sat straight, then i used about 6 large washers to space it up so the seat wasnt sitting at an angle. the 4th bolt lines right up.
If you dont want to cut things off or drill new holes in the floor board you can always go to homedepot and get a flat metal rod. They go for like 5 bucks. Make your measurements and take a grinder and cut the brackets. I have 95 Black cloth GSR seats in my CRX.
Just2Fast
Jul 6, 2006 09:00 AM
FinestImage12
Oct 20, 2004 08:32 AM
