teg brakes on to civic
Old Oct 23, 2003 | 06:35 PM
eg686's Avatar
Default teg brakes on to civic
96 LS 4 disc brakes bolt straight up to 98 civic right? I got in a wreck so I want to make sure it is direct bolt on to civic? will I have any trouble making them fit considering that I have taken everythign off from a teg?
Old Oct 23, 2003 | 08:43 PM
eg686's Avatar
Default Re: teg brakes on to civic (DC8811)
bump
Old Oct 24, 2003 | 02:59 AM
Jdm_Rice_Monster's Avatar
They should fit, do a search
Old Oct 24, 2003 | 07:38 AM
Run Hatch's Avatar
They should bolt right on with no problem.
Old Oct 24, 2003 | 09:11 AM
phantom_sol's Avatar
UM....
calipers wont just bolt up. but if you have the 99-00 civic si, 94-00 integra, or 92-95 civic ex/si knuckles. then it will. if you can get all the brakes WITH the knuckles then you are set. be sure to use a ball joint puller. knocking them out with a persuader is NOT a good idea.
Old Oct 24, 2003 | 09:15 AM
kommon_sense's Avatar
Default Re: (phantom_sol)
what civic do you currently have?
you may also need EX/SI MC and brake booster as well as 99-00 SI prop valve.
Old Oct 24, 2003 | 09:16 AM
EL Vap133's Avatar
Make sure you use your stock LCAs...
Old Oct 24, 2003 | 03:00 PM
eg686's Avatar
Default Re: (kommon_sense)
I drive a 98 dx coupe
Old Oct 24, 2003 | 03:24 PM
EL Vap133's Avatar
Default Re: (DC8811)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC8811 &raquo;</TD></TR><TR><TD CLASS="quote">I drive a 98 dx coupe</TD></TR></TABLE>
Yup they will fit, just get 00 si e-brake cables if the Teg e-brake cables don't fit...
Old Oct 24, 2003 | 04:10 PM
then you can keep your prop valve, but you will need the MC and booster from a 96-00EX or 99-00SI.
Old Oct 24, 2003 | 09:30 PM
eg686's Avatar
thanx
BlueIntegraBoy
Jul 25, 2005 06:39 PM
DSRxMilogen
May 21, 2004 06:07 AM
turboex
Jan 26, 2004 04:54 AM
slammed EG
Jan 22, 2004 01:33 PM
cdn90civicsi
May 13, 2003 11:26 AM
