DC5 ITR Head
Old Oct 23, 2003 | 06:32 PM
Tom5's Avatar
Default DC5 ITR Head
I am in the market for a ITR head including intake and exhaust manifolds. I was just wondering what i would need/be involved with this swap? I have heard that the K20A and the K20A2 heads are very close buy I see otherwise. I plan on getting the Hondata K20A reflash - will that work with that Type R head or will I need a K20A ECU also? I just want to be safe with high revving, and I already have someone inline to buy my stock head. Give me some advise.
Tom
Old Oct 24, 2003 | 06:20 AM
GoodKnight's Avatar
Default Re: DC5 ITR Head (Tom5)
I'm assuming you have a k20a2 already. If that's the case, the head from a k20a should be a direct swap. The hondata k20a reflash should work with the type-r head, and you should be able to use your k20a2 ecu. Might want to verify with hondata first though.
Old Oct 24, 2003 | 06:23 AM
B18CXr's Avatar
Tom
and ITR head will only work on an B-series block, not a K-series
Old Oct 24, 2003 | 06:25 AM
GoodKnight's Avatar
Default Re: DC5 ITR Head (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> I am in the market for a ITR head including intake and exhaust manifolds. I was just wondering what i would need/be involved with this swap? I have heard that the K20A and the K20A2 heads are very close buy I see otherwise. I plan on getting the Hondata K20A reflash - will that work with that Type R head or will I need a K20A ECU also? I just want to be safe with high revving, and I already have someone inline to buy my stock head. Give me some advise.
Tom
and ITR head will only work on an B-series block, not a K-series</TD></TR></TABLE>
Pretty sure he means the dc5 itr, in which case it comes with the k20a motor. The parts on the k20a, for the most part, are compatible with the usdm k20a2.
Old Oct 24, 2003 | 09:11 AM
Solo2Vtec's Avatar
Did you not read the title of the post?
Old Oct 24, 2003 | 07:42 PM
Steve26's Avatar
Tom
Yep, he is definately talking about the DC5 ITR not DC2 ITR. From what I know it should all work nicely. Post your results if you go through with it.
Old Oct 25, 2003 | 01:08 AM
K20EG's Avatar
Default Re: DC5 ITR Head (Steve26)
keep us posted on this swap
Old Oct 25, 2003 | 05:56 AM
B18CXr's Avatar
Default Re: DC5 ITR Head (Solo2Vtec)
you have ever seen an Integra Type R DC-5????
proper nomenclature is a good thing....
Old Oct 26, 2003 | 02:04 PM
Tom5's Avatar
Hey Jack, I have been to P1 a couple of times and you tried to sell me some toda cams and valve springs. Theres a guy who frequently visits your shop down there he has a 02 EP wheels, springs, CAI, and VAFC-II its black you prolly know him. He is thinking about buying my stock head off of me and then with that money I will hopefully get the K20A head. Do you think he will need a K20A2 ECU or what? And for me will I need the K20A ECU? or can I do the Hondata K20A reflash?
Tom
Old Oct 27, 2003 | 05:00 PM
nickzed20's Avatar
correct me if im wrong, but arent the K20A and K20A2 heads the same part, just with a different valvetrain and manifolds. I think it would be alot simpler to just buy that stuff instead of the whole unit? why go through the hassel of reaplacing and selling the current one?
Old Oct 27, 2003 | 07:44 PM
jdkindle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tom5 &raquo;</TD></TR><TR><TD CLASS="quote">I am in the market for a ITR head including intake and exhaust manifolds. I was just wondering what i would need/be involved with this swap? I have heard that the K20A and the K20A2 heads are very close buy I see otherwise. I plan on getting the Hondata K20A reflash - will that work with that Type R head or will I need a K20A ECU also? I just want to be safe with high revving, and I already have someone inline to buy my stock head. Give me some advise.
Tom </TD></TR></TABLE>
You have to use the USDM ECU for any of the Hondata flashes, and you will have no problems because.................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickzed20 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but arent the K20A and K20A2 heads the same part, just with a different valvetrain and manifolds. I think it would be alot simpler to just buy that stuff instead of the whole unit? why go through the hassel of reaplacing and selling the current one?</TD></TR></TABLE>
You are correct
Old Oct 27, 2003 | 08:14 PM
1abSi's Avatar
Default Re: DC5 ITR Head (jdkindle)
yeah you guys can just do the head stuff and keep you ecu's...and either go hondata or for the EP guy have someone at acura flash it....might cost you though
Old Oct 28, 2003 | 12:40 AM
SuperTwinz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> Did you not read the title of the post?
proper nomenclature is a good thing....</TD></TR></TABLE>I've seen some.
Old Oct 29, 2003 | 02:51 PM
IslandR's Avatar
YEAH I have seen a DC5 type R.
What kind of stupid question is that anyway?
What planet are you on? Didnt you know there was a HOnda DC5R in japan?
well if you didnt there here is link to see mine. FYI - They have been around since probably late 2000.
HOnda integra type r
http://www.imagestation.com/album/?id=4288747853
Old Oct 29, 2003 | 02:52 PM
SuperTwinz's Avatar
Default Re: DC5 ITR Head (tmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmac &raquo;</TD></TR><TR><TD CLASS="quote">YEAH I have seen a DC5 type R.
http://www.imagestation.com/album/?id=4288747853 </TD></TR></TABLE>I think he was joking.
Old Oct 29, 2003 | 04:07 PM
Tom5's Avatar
Default Re: DC5 ITR Head (SuperTwinz)
I wonder if he will give me his head?????? Cmon NO CHARGE!!!
Old Nov 8, 2003 | 03:12 AM
DC5TypeR's Avatar
Yes i have i own one? Really you boys in the states call it a RSX but the Type R version i have is called Integra in Japan.
Old Nov 8, 2003 | 01:46 PM
Downey's Avatar
The RSX isnt called RSX in Japn.. its still called Integra and they do have an Integra Type R. just in case you didnt know..
mynameizstitch
Apr 8, 2013 07:43 PM
hondaholic13
Apr 5, 2012 05:36 AM
meckas792
Aug 13, 2009 07:18 AM
cam3ron88
Sep 15, 2006 05:01 PM
atec
Apr 9, 2006 04:21 AM
