Whats needed in Mini-Me?
Hey all, i have a friend that blew his head gasket out in his 89 Civic Si. i told him to do a mini-me swap instead of just getting a new head gasket. other than the z6 head what all is needed? can u use stock ecu?
Thanks
Thanks
i just gave this link to a guy 5 mins ago...i used search and found it in 10 seconds.
https://honda-tech.com/zerothread?id=554053
Yeah it will work with the stock (PM6) ECU - but you really need either a '90 or '91 PM6 if you want it to run the best w/that ECU. Other than that, you can use either the Z6 or Y8 headgasket (y8 is cheaper and thinner = higher CR). Use either the Z6 or Y8 timing belt as well (again, Y8 is cheaper). Other than that, pretty much everything should bolt up - but your A6 distributor is going to be way off.
It will work w/out any sort of vtec or fuel management. Problem is you'll constantly be running in the low camshaft lobe, and it's gonna be running too rich. If you get some sort of a vtec switch without any fuel management, it will run too lean during vtec. So either way it will work, but it's not going to live up to it's full potential.
Personally, I don't recommend Z6 mini-me's. If you're going to use the Z6 head, you should go for the entire package (Z6 longblock), and then convert to OBD-1. I wouldn't do it any other way. The Y8 head is a slightly different story though....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd »</TD></TR><TR><TD CLASS="quote">
Personally, I don't recommend Z6 mini-me's. If you're going to use the Z6 head, you should go for the entire package (Z6 longblock), and then convert to OBD-1. I wouldn't do it any other way.</TD></TR></TABLE>
I answered to post like this awhile back and wrote my reasons why I would do it the way I would if I came across this. Do a search and hopefully my post will come up again. Im just too tired right now to explain myself again.
Basically, it sums up to what MR. TODD said. ( with added detail )
If anyone can find that link, please provide it for this gentleman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX »</TD></TR><TR><TD CLASS="quote">Hey all, i have a friend that blew his head gasket out in his 89 Civic Si. i told him to do a mini-me swap instead of just getting a new head gasket. other than the z6 head what all is needed? can u use stock ecu?
Thanks</TD></TR></TABLE>
Ooooooh man not to be a dick but there is literally HUNDREDS of the infamous mini-me threads lurking around the search archives.....read em' up!
kartracer4
Jun 25, 2005 01:28 PM
sleepyhamsterlx
Jan 5, 2004 08:21 PM
