Negative effects of leaving fan on?
Old Sep 4, 2001 | 08:04 AM
bigTom's Avatar
Default Negative effects of leaving fan on?
are there any negative effects of leaving the rad. fan on constantly during driving? where as u just have a switch to turn it on when u turn the car on? i know a car with this but havent really asked specifics about it
Old Sep 4, 2001 | 09:20 AM
bigTom's Avatar
Default Re: Negative effects of leaving fan on? (Teken)
ummm... to cool the water? duh?
Old Sep 4, 2001 | 09:38 AM
Spade's Avatar
Default Re: Negative effects of leaving fan on? (ek9t)
If you have alot of electrical stuff (i.e. Big stereo and other toys) pulling power then yes, your alt will be doing overtime but, if all you have is a basic stereo and maybe some foglights then NOPE, will be fine, loud but fine.
Old Sep 4, 2001 | 12:31 PM
Honda318dx's Avatar
I have my fans staying on all the time but I mainly track my car, so staying cool is important!
Old Sep 4, 2001 | 01:21 PM
synergy004's Avatar
Default Re: Negative effects of leaving fan on? (Honda318dx)
same here, I have a constant fan, ofcoarse a turbo LS motor in a 92 HB needs some air. Especially if you like I have a huge front mount in the front. If your using it for cooling purposes because your engine bay gets hot then do what i did. The only negative affect I know of is that it can less the life of the motor on the fan. My bros went out, SOLUTION. 50 bucks gets you a thinner more larger electric fan which is easy to install. He went to AUTOZONE for that.
hope this helps.
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
KillerElfboy
Jun 22, 2006 07:26 PM
FONK
Jan 12, 2006 03:03 PM
wsiracerz
Jun 7, 2004 12:08 AM
B_1_8_hatch
Jan 23, 2003 07:03 PM
