JDM 1st gen B16 swap
Old Oct 23, 2003 | 03:38 PM
nick91civicsi's Avatar
Default JDM 1st gen B16 swap
hey all
im looking into upgrading from my zc to the 1st gen jdm b16 swap and im having trouble finding info on the swap so if anyone can give me some info or a helpful link i would appreciate it.... one of my major concerns is if the parts will be harder to find than those for a newer gen b16 or if the parts would be the same, but also ALL the exact parts that i will need to complete the swap, and if the stock jdm mounts and shift linkage will work in a 91 si hatchback?
thanks for any help
Old Oct 23, 2003 | 03:43 PM
roadawg's Avatar
Default Re: JDM 1st gen B16 swap (nick91civicsi)
https://honda-tech.com/zerosearch
Old Oct 23, 2003 | 03:45 PM
EL Vap133's Avatar
LOL, you can also try http://www.Hasport.com
Old Oct 23, 2003 | 04:41 PM
XJamesX's Avatar
Default Re: JDM 1st gen B16 swap (EL Vap133)
Her is a list of parts and part #'s for a B16 most newer B16 parts will work.
All parts that say Del sol it is for the Dels sol Dohc Vtec
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
-James-
Old Oct 23, 2003 | 07:57 PM
thanks alot for the list, that will really come in handy.... as for the search, i had trouble finding anything thats why i asked....
killakush21
Mar 9, 2013 11:32 AM
evilsolb16
Sep 5, 2004 01:22 PM
Fatty_1775
Jul 27, 2004 05:42 PM
-16V-
Oct 2, 2002 09:46 PM
